Hi all,
I have multiple Philips Hue lamps in my setup. I am turning them on by using a dummy-shelly, which triggers an automation, which in turn activates a scene. That scene defines the lamps that should turn on, their brightness, and their color temp. The scene includes a Philips pendant light (two seperate entities, one up, one down) and three standard bulbs. They all have different values set in the scene.
I recently updated to Home Assistant core 2022.9.0.dev20220826. Since then, the two lights in the pendant light give a quick flash every time they are turned on via a scene (i.e. turn on, immediately turn off and turn on again - all in a matter of less than a second).
This was not the case before the HA update. The bulbs work just fine, only the pendant light is affected.
I did some troubleshooting:
- Turning on lamps via Philips Hue app → works fine
- Turning on lamps directly in the HA app (no automations/scenes) → works fine
- Activating scene directly (no automation) → LAMP FLASHES
- Integrating lamps directly into the automation (no scenes) → works fine
So it seems like there is an issue with the scene. I am pasting the code of the scene below:
- id: '1615232060883'
entities:
light.hue_color_pendant_up_1: # THIS ONE FLASHES
min_mireds: 153
max_mireds: 500
effect_list:
- None
- candle
- fire
supported_color_modes:
- color_temp
- xy
color_mode: color_temp
brightness: 255
color_temp: 230
hs_color:
- 26.722
- 28.925
rgb_color:
- 255
- 214
- 181
xy_color:
- 0.401
- 0.359
effect: None
mode: normal
dynamics: none
icon: mdi:wall-sconce-flat-variant
friendly_name: Esstischlampe oben
supported_features: 44
state: 'on'
light.hue_color_pendant_down_1: # THIS ONE FLASHES
min_mireds: 153
max_mireds: 500
effect_list:
- None
- candle
- fire
- color_temp
- xy
brightness: 175
color_temp: 359
hs_color:
- 28.217
- 63.073
rgb_color:
- 255
- 169
- 94
xy_color:
- 0.517
- 0.386
effect: None
mode: normal
dynamics: none
friendly_name: Esstischlampe unten
state: 'on'
light.stehlampe_oben:
min_mireds: 153
max_mireds: 454
- color_temp
brightness: 255
color_temp: 346
hs_color:
- 28.016
- 59.968
rgb_color:
- 255
- 173
- 102
xy_color:
- 0.507
- 0.384
mode: normal
dynamics: none
icon: mdi:floor-lamp-dual
friendly_name: Stehlampe oben
supported_features: 40
state: 'on'
light.stehlampe_mitte:
min_mireds: 153
max_mireds: 454
- color_temp
mode: normal
dynamics: none
friendly_name: Stehlampe mitte
brightness: 255
color_temp: 346
hs_color:
- 28.016
- 59.968
rgb_color:
- 255
- 173
- 102
xy_color:
- 0.507
- 0.384
state: 'on'
light.stehlampe_unten:
min_mireds: 153
max_mireds: 454
- color_temp
mode: normal
dynamics: none
friendly_name: Stehlampe unten
brightness: 255
color_temp: 346
hs_color:
- 28.016
- 59.968
rgb_color:
- 255
- 173
- 102
xy_color:
- 0.507
- 0.384
state: 'on'
switch.schalter_entertainment:
icon: mdi:light-switch
friendly_name: Schalter Entertainment
state: 'off'
switch.schalter_kuche:
friendly_name: Schalter Küche
state: 'on'
icon: mdi:silverware
metadata: {}
I would like to keep using scenes (or a reasonable alternative), as it makes setup and maintenance a lot easier than setting the different light settings in various automations.
Do you have any idea what the issue is here and how it can be resolved?
Thanks a bunch!
//Edit: I have setup the scene via the visual editor in HA core-2021.4.3
