I have an automation set to switch on a floor lamp to a particular brightness when the front door is unlocked at night, which has worked fine for months, but suddenly stopped working a few days ago (may have aligned with one of the 2024.4.x releases).
The automation checks the light is off first, so it doesn’t suddenly crank it up bright if someone’s already home and has it down low.
Traces show the automation stops when it checks to see if the light is off.
Should I be checking the light status a different way? Or has some Hue integration bug appeared? I built the automation using the editor, but here’s the YAML:
alias: Lamp on when getting home
description: ""
- platform: state
entity_id:
- sensor.front_door_lock_status
to: Unlocked
condition:
- condition: sun
before: sunrise
after: sunset
- condition: device
type: is_off
device_id: 0f764e22743e62c42f80d00cc5af6c2b
entity_id: de358d849f37959e3153c998f90d2a01
domain: light
- type: turn_on
domain: light
brightness_pct: 75
mode: single
Agreeing with @Stiltjack said… I’m willing to bet one of the device ids changed from the integration and that’s what is causing it. Changing to entity ids will prevent this from happening when device ids change (and they do sometimes change ).
Thanks everyone. I tried rewriting the automation with entity states instead of device states and it does now seem to work. Weirdly, I checked and the device/entity IDs hadn’t actually changed, so who knows what was actually going wrong. Still better to be using the entity names now.
For anyone looking for what a working version of the above YAML, here it is. I was tripped up by entity brightness being an integer (0-255) instead of a percentage like with the device version. Not sure why they’re inconsistent like that.
description: ""
- platform: state
entity_id:
to: Unlocked
condition:
- condition: sun
before: sunrise
after: sunset
- condition: state
entity_id: light.floor_lamp
state: "off"
- service: light.turn_on
metadata: {}
brightness: 191
mode: single
