I’m trying to create a Halloween automation where my Hue lights flicker for a few seconds, and then my animatronic zombies would turn on. I’m not sure how to set up a strobe/lightning/flicker effect for the Hue. Can anyone help?
As Halloween gets closer people will be posting thier automations. Several lights don’t support it, but have you tried ‘flash’ in the light.turn_on service call?
‘effect’ looks interesting also:
effect
yes Applies an effect such ascolorloop
orrandom
I wonder if there are any other effects?
Thanks for the suggestion. I gave flash a try. It simply turned the lights on and then back off one time. I tried stringing together multiple flashes, but that didn’t really replicate a flicker or strobe. I also tried turning the lights on and off several times, but that didn’t really work either. I think the problem is the default transition of Hue lights is too slow, Rather than a straight on/off, it transitions to on and off over the course of about 1/4 second. That doesn’t sound like much, but it is enough to spoil the effect.
@_Mike flash has two options ‘short’ and ‘long’. Long gives 10 flashes I think, short just one.
Thanks for the info. I’ll give that a try. I just wish you had sent it prior to Halloween!
As I was looking for something similar and didn’t find something, I asked ChatGPT to create an algorithm to simulate lightning effects.
I have put it in a small github project for people to (re)use:
Hi @slyoldfox, I landed on this page with your GitHub project having some disco sort effects for my Hue led strips.
The scenes I can create in the Hue iOS app (if you save a created scene they will show-up in HASS by using the Hue integration (Philips Hue - Home Assistant) are limited.
For example I cannot create an effect together with a 3-color gradient. When choosing an effect in the Hue iOS app I can only choose 1 color. Besides that are the effects limited. There is not really a party/disco mode or strobe mode.
So I really like to use and check your project. But the readme on the installation is a bit limited related to my knowledge. For example how do I " Run npm i
to install the dependencies" and how do I run the javascript nod a make the calls?
Would it be possible to give some additional instruction how to setup each step?
Thank you very much for your help
You just install node from nodejs.org …
