Hue lights automation combination
Hi. This is probably quite straightforward but I am clearly too inept to sort this out…
I have a light on my front door (hue bulb) which I have an automation to turn on when the light level of another outdoor sensor (a hue outdoor motion sensor which is not at my front door but elsewhere outside my house) falls below 50. This works.
I also have a motion activated automation for the same hue front door light which uses the motion sensor of my unifi protect doorbell to turn the light on when motion is detected. This works.
What I am struggling to do is combine the two in such a way that the following happens…
Once the illuminance of the hue outdoor sensor falls below 50 I want the front door light to go on at 25% and stay on in this dimmed state until the illuminance goes back above 50 - basically I am using the light values to manage when it is dark enough to bother having the light on. If the motion sensor (from the doorbell) is triggered, I want the light to go to 100% and then after say 1 minute go back to the previous dimmed state of 25%.
