Hue Lights Won't Transition When Called by Scene
I’ve been having issues with transitions and Hue bulbs. When an automation is calling to activate a scene using a transition time, the bulb will not transition - it will only turn on. However, if I code it by hand in full in the automation calling the device or entity it will transition fine.
This automation fails to fade. The scene is comprised of one Hue spot bulb.
description: ''
  - platform: time
    at: '00:00:00'
condition: []
  - service: scene.turn_on
      transition: 30
      entity_id: scene.fade_test_scene
    metadata: {}
mode: single
This automation transitions fine. It does the same thing as the Scene.
description: ''
  - platform: time
    at: '00:00:00'
condition: []
  - service: light.turn_on
    entity_id: light.hue_color_spot_1
      brightness_pct: 50
      transition: 30
mode: single
I have this issue with Hue spots and downlights, but seemingly not Hue standard lamps. When bulbs are in a scene those will fade; however, everything else will just turn on.
Help would be greatly appreciated.
