Hello @ all,
I have a problem setting up Hue Lux Bulbs, which can only do warm white to cold white… If I set them up via ZHA, it only gives me the brightness option, but no white temperature option. Is there any chance to correct this behaviour ?
I have a similar problem with some ELGO Connect.2 bulbs, which have white temp and rgb, not recognizing the rgb part, while the white temperature is there…
So confusing…
