Hue Motion Sensor Device class
I try to get my hue motion sensors to the right device class (motion)
my code is
and customize
 sensor.gang_boven_motion:
    icon: mdi:account-alert
    device_class: motion
anyone got a idea?
HI this is in my sensors.yaml:
  - platform: rest
    resource: http://x.x.x.x/api/xxxxxxxxxxxxxxxx/sensors/22
    value_template: '{{ value_json.state.presence}}'
    scan_interval: 10
I have the same result - is it the word ‘True’ you are trying to change?
Yes, i want them both to be clear or the other one :stuck_out_tongue:
Try to put the device_class under the REST sensor, my config and it act like clear/detected:
- platform: rest
  resource: http://_IP_/api/_key_/sensors/12
  value_template: '{{ value_json.state.status }}'
  name: 'Beweging woonkamer achter'
  scan_interval: 2
Nope, no diferance
Mine all have clear as well (mixture of Hue and Xiaomi), so the one with true seems to be the odd one. Can you post code of both? How do they look in the “Current entities” list?
Enity
sensor.gang_beneden_motion False
friendly_name: Gang Beneden Motion
code
I think i see the difference,
value_template: ‘{{ value_json.state.status }}’
and
value_template: ‘{{ value_json.state.presence }}’
When i use
i’m getting nu state at all.
Try using a binary_sensor instead of a sensor. This should allow you to use the device_class configuration variable.
I think you are using a virtual sensor for one and not for to the other sensor. That’s the reason you get no state info when changing from ‘state’ to ‘presence’. Set them both to the corresponding sensor ID (look for presence) as given in the CLIP API Debugger.
