Even if it works, it’s seems like a bit odd way to solve the problem?
What is the “normal” procedur/most common way to set up Hue indoor motion sensor, that not give tons of activations?
5 minutes. Turning off works fine, just the on commands over and over again, as long there is motion, which is unnecessary. But everything actually works fine, just the on-spamming that disturbing me.
platform: state
for: '00:05:00'
to: 'off'
entity_id: binary_sensor.kitchen_sensor_motion
Not at all. The primary job of a motion sensor is to report motion when it occurs. How you use that information is independent of the sensor’s basic operation.
Some have a factory-set ‘cooldown’ (or ‘shutdown’) period where they won’t report they have detected motion if they just reported it less than X seconds/minutes ago. Battery-powered motion sensors tend to have longer cooldown periods in order to preserve battery-life. Mains-powered sensors can have a very short cooldown period (if any).
Depending on the intended application, this cooldown period can be an advantage or a disadvantage. A cooldown of 5 minutes would be a disadvantage if the goal is to promptly know when there’s no motion.
FWIW, all of my motion sensors are mains-powered so they have very short cooldown periods (and it’s not adjustable).
There is also the concept of an occupancy sensor. It instantly reports the first sign of motion, but it only reports ‘no motion’ after none has been detected for at least a minute (or more). For example, I sensors that report both motion (i.e. reports motion the moment it’s detected with a short cooldown period) and occupancy (i.e. reports no occupancy reported when there has been none for at least 1 minute). Effectively, that’s what you created when you added the option for: '00:05:00'
In my case, I have excluded all motion sensors from the recorder integration because I have no interest in seeing the history of motion events.
