Wups… That seem to fix my problem… Thank you @ludeeus!
Hey M or anybody who kind of knows what there doing I have been using this code to disable, enable the motion sensors as a command line switch:
bedroom_sensor_switch:
friendly_name: 'bedroom motion detector switch'
command_on: >
curl -X PUT -d '{"on":true}' "http://192.168.1.10/api/redacted/sensors/3/config/"
command_off: >
curl -X PUT -d '{"on":false}' "http://192.168.1.10/api/redacted/3/config/"
command_state: 'curl http://192.168.1.10/api/redacted/sensors/3/'
value_template: '{{value_json.config.on}}'
and I noticed this error (?lately)
Error parsing value: ‘value_json’ is undefined (value: None, template: {{value_json.config.on}})
Is there something wrong with the code or is it something else. The switches still appear functional in my frontend
Thanks all
NVM
Mariusthvdb provided the answer here but kind of a weird switch in the front end now
https://community.home-assistant.io/t/toggle-phillips-hue-sensors-on-off-from-hass/36734/13
Is this one supported in the component? The new Philips outdoor sensor that is
Yes, the outdoor sensor looks just like the indoor sensor in HA. Works like a charm once you have the custom component sorted.
Yes - go to the Github page, go to Releases and get v0.8 there - the old instructions are included in the zip file
No problems with the custom component?
you have one installed?
could you please share a screenshot of the attributes it has? I can’t find any documentation from Philips showing what features it supports, other than motion (lx, light level, temperature, battery, etc etc)
I mean this more-info:
a screen from the api too would be great please?
what’s weird about it?
Ive changed the switches a bit:
laundry_motion_sensor_switch:
friendly_name: 'Laundry motion sensor switch'
command_on: >
curl -X PUT -d '{"on":true}' "http://192.168.1.212/api/redacted key/sensors/22/config/"
command_off: >
curl -X PUT -d '{"on":false}' "http://192.168.1.212/api/redacted key/sensors/22/config/"
command_state: !secret get_laundry_config
value_template: >
and use this customization:
switch.laundry_motion_sensor_switch:
templates:
icon: >
if (state === 'on') return 'mdi:toggle-switch';
return 'mdi:toggle-switch-off';
assumed_state: false
group:
group.philips_motion_sensor_switches:
friendly_name: Laundry motion
Is this good enough?
Exactly the same features as the indoor one. Probably same hardware too, just different casing.
None. Was using v0.8 before. Only issues are a few more errors in the log but none that are actually causing problems. I prefer this to the problems described using the latest version of the CC.
Thanks. Fancy
Ahem I’ll just copy this …like pretty much everything else I have in my config lol. At least its starting to make some sense.
Just to confirm are you using:
value_template: >
or something like
value_template: >-
"{{ is_state('sensor', 'on') }}"
Edit:
The second way doesnt have the correct initial state shown in the front end and the first way I think gave me an error so ?
thank you very much for confirming!
ordered one;-)
just to be sure: the command_state: with the !secret needs the correct command in the secrets.yaml file of course, did you do that?
what {{value_json.config.on}}
does is check the value of the attribute on
, to see if its true or false. theoretically you could use other value_templates, but this should really be it, in combination with the command_state
what error do you see?
din_liv_rm_sensor_switch:
friendly_name: ‘dining room motion detector switch’
command_on: >
curl -X PUT -d ‘{“on”:true}’ “http://192.168.1.10/api/redacted/sensors/9/config/”
command_off: >
curl -X PUT -d ‘{“on”:false}’ “http://192.168.1.10/api/redacted/sensors/9/config/”
command_state: ‘curl http://192.168.1.10/api/redacted/sensors/9/’
value_template: ‘{{value_json.config.on}}’
I have been lately with my secrets.yaml especially bc allot is in flux right now. This is what I had originally but I had the error. Ill put it back and get back to you about the error
if anything, be ware of simply copying from this community posts, editors tend to change the quotes into curly quotes, and the HA yams engine doesn’t except these.
Just look at your post and see all left quotes to be incorrect now.
Not saying that caused your error, but it would now
confused
Which quotes are wrong?
It passes check config in the frontend?
I’ll keep an eye on it but I think I see what you mean copying back and forth from notepad ++ to these posts
and all the other quotes really that start and finish, should be
Apologies, having an issue on getting my Motion Sensor to show up in HA after re-installing. I barely have any idea on how to run anything Python related as mentioned here:
Parse the json file using the hue_sensors package and report the device ID (e.g. RWL_06-02) that is causing your issue.
Querying the bridge like it says here: Hue-sensors-HASS shows my sensor under the ‘sensors’ section: Imgur: The magic of the Internet
But it doesn’t show up in HASS anymore. It used to come up as sensor.front_door_motion_sensor. Doesn’t seem like I get any errors on startup either. My other Hue lights (normal integration) work fine.
Hi. I’m running 0.88.2 and I have custom_components\sensor\hue.py installed. I’d like to remove it. What steps should I follow? Should I delete the entire custom_components folder (with it sub-folder and content), remove any config file references and then reboot?
