I want an automation to change my hue lamp color to a random color every 1 minute. But I only want to turn on after sunset. Can someone help me with this automation. I am new and just getting into automations.
Use something like:
- alias: Lights - Random Color Every Minute
- platform: time
minutes: '/1'
seconds: 00
condition:
- condition: state
entity_id: sun.sun
state: 'below_horizon'
- service: light.turn_on
entity_id:
- light.media_center_lighting
effect: random
Thanks for the response.
Is there a way to make it so the light is only on for 3 hours after sunset?
Add another automation to turn_off lights after 3 hours.
That code turns on the automation but when you turn the light off it turns back on.
YeahâŠthat automation was a very simple example of how to go about it. It does what you mentioned in the original post. You should use that as a base to handle other conditions like the one you added.
I wrote this a while back.
Trigger the script execution using a time trigger and a condition to only fire after a certain time.
Thanks for the information. While I got these items to show on the front end. I am unable to get it to work. I canât get the script to trigger my light.sink_lamp
I got the light to turn on but I get this in my error log.
ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: âcolorsâ is undefined
My code has evolved a bit. This is what I am currently running for 3 different lights (only one in code below = kitchen_high, but you can easily copy that script, rename it and call the script.preprocessor with another id). An important thing to keep in mind is that you should not call the script multiple times at the same time, as it will produce an error that the script was still running.
To configure the brightness and saturation (these are not randomly selected, only the hue is), I am using two sliders in my UI. They are called input_number.movie_night_saturation and input_number.movie_night_brightness.
SCRIPTS
change_kitchen_high:
alias: Change Kitchen Top Light
sequence:
- service: script.preprocess_color
# this script choses a random color for the lights
preprocess_color:
sequence:
- service: script.set_color
data_template:
id: '{{ id }}'
colors: >-
{%- set h = (range(0, 360)|random)/360 %}
{%- set s = states.input_number.movie_night_saturation.state|float %}
{%- set v = states.input_number.movie_night_brightness.state|float %}
{%- set i = (h * 6)|int %}
{%- set f = h * 6 - i %}
{%- set p = v * (1 - s) %}
{%- set q = v * (1 - f * s) %}
{%- set t = v * (1 - (1 - f) * s) %}
{%- if i % 6 == 0 %}
{% set r = v %}
{% set g = t %}
{% set b = p %}
{%- elif i % 6 == 1 %}
{% set r = q %}
{% set g = v %}
{% set b = p %}
{%- elif i % 6 == 2 %}
{% set r = p %}
{% set g = v %}
{% set b = t %}
{%- elif i % 6 == 3 %}
{% set r = p %}
{% set g = q %}
{% set b = v %}
{%- elif i % 6 == 4 %}
{% set r = t %}
{% set g = p %}
{% set b = v %}
{%- elif i % 6 == 5 %}
{% set r = v %}
{% set g = p %}
{% set b = q %}
{%- endif %}
{{ (255*r)|round(0) }}, {{ (255*g)|round(0) }}, {{ (255*b)|round(0) }}, {{ (360*h)|int }}
transition: 10
set_color:
sequence:
data_template:
entity_id: '{{ id }}'
rgb_color: [ "{{ colors.split(',')[0]|int }}", "{{ colors.split(',')[1]|int }}", "{{ colors.split(',')[2]|int }}" ]
transition: "{{ transition }}"
AUTOMATION
The following automation changes the kitchen colored light after 8pm, every 20 minutes, but only if they are on
- alias: Kitchen colored lights change after 20:00
platform: time
minutes: /20
seconds: 30
condition:
condition: and
conditions:
- condition: state
entity_id: light.kitchen_high
state: 'on'
- condition: time
after: '20:00:00'
- service: script.change_kitchen_high
INPUT NUMBERS
movie_night_saturation:
name: Color Saturation
initial: 0.4
min: 0
max: 1
step: 0.05
mode: slider
movie_night_brightness:
name: Color Brightness
initial: 0.8
min: 0
max: 1
step: 0.05
mode: slider
I hope that helps.
Thank you. I got it working.
Any upddates on this, how to make it run on 0.118.3? The simple part, the automation, works fine. The script does not seem to change the colour of my TrĂ„dfri bulb. Note, I hade to change the platform to time_pattern and not use â/xâ for the âeveryâ-part of the story.
Ditto what @Marcus_Jansson said - my code like this has recently stopped working, but Iâm not sure why. I can see the automation and all scripts firing, so Iâm not sure what the problem is. Anyone have any thoughts or advice? Not sure where to look nextâŠ
EDIT: Found another example online that fixed things, and condensed it all down to one automation without any extra scripts:
- alias: LightsHue - Rotating Hue Colors Every Two Seconds
initial_state: True
- platform: time_pattern
seconds: '/2'
condition:
- condition: state
entity_id: light.office
state: 'on'
data_template:
hs_color:
- "{{ (30 + (state_attr('light.office', 'hs_color')[0] or 0)) % 360 }}"
- 100
brightness_pct: 100
transition: 2
Obviously update your light names as needed. Hope this helps someone else!
