Hue scenes mimicked in Ha (and on Buttons, was Tiles)
Do you have an example, I’m probably overlooking this, but I checked here:
and here:
I have the button-card installed with hacs and linked the resources.
Correct, it says:
In ui-lovelace.yaml (or in another file using !import)
button_card_templates:
  header:
    styles:
      card:
        - padding: 5px 15px
        - background-color: var(--paper-item-icon-active-color)
      name:
        - text-transform: uppercase
        - color: var(--primary-background-color)
        - justify-self: start
        - font-weight: bold
      label:
        - font-weight: bold
so add the other templates there using the same indent as this example template ‘header’
yes so when I add that and the rest of the example I have this at the top of my ui-lovelace.yaml
  header:
    styles:
      card:
        - padding: 5px 15px
      name:
        - font-weight: bold
      label:
        - font-weight: bold
  header_red:
    template: header
    styles:
      card:
        - background-color: '#FF0000'
then when I add a card I get this error:
what happens if you only use the ‘header’ template. in a custom:button-card in a lovelace card (not in another template)
btw, to keep your ui-lovelace.yaml clean you could do this:
button_card_templates: !include lovelace/includes/button_card_templates.yaml
and have all templates in that file. Thats the way I do it
Yes I had the include in there, but removed everything and started over since I didn’t know where the error was coming from.
like this?
Did you reload resources ?
yes, I did.
Have to go now, but post your ui-lovelace.yaml on formatted code and we can check properly
ok I will. I feel like there’s a problem with how home assistant reads my ui-lovelace.yaml. Because my raw config-editor is very different.
my ui-lovelace.yaml:
  header:
    styles:
      card:
        - padding: 5px 15px
      name:
        - font-weight: bold
      label:
        - font-weight: bold
  header_red:
    template: header
    styles:
      card:
title: NiMa
  - badges: []
    cards:
      - entities:
          - entity: person.nick
          - entity: binary_sensor.someone_home
          - entity: person.marieke
        show_icon: true
        show_name: false
        show_state: true
        type: glance
      - entity: weather.nima
        type: weather-forecast
      - entities:
          - entity: sensor.buienalarm_next_rain_forecast
          - entity: sensor.buienalarm_temperature
          - entity: sensor.buienalarm_precipitation
          - entity: sensor.buienalarm_precipitation_forecast_average
          - entity: sensor.buienalarm_precipitation_forecast_total
        title: Buienalarm
        type: glance
      - entities:
          - entity: sensor.cpu_temperature
          - entity: sensor.processor_use
          - entity: sensor.memory_use_percent
        type: glance
      - analogFace: face-006
        analogPlacement: bottom
        analogShowDate: bottom
        analogSize: 200px
        clockBold: false
        dateFormat: DD/MM/YYYY
        displaySeconds: true
        displayType: both
        secondsColor: red
        showDate: true
        showWeek: true
        timeFormat: 24
        timezone: Europe/Madrid
        type: 'custom:mm2-clock-card'
    icon: 'mdi:information'
    title: Info
  - badges: []
    cards:
      - cards:
          - entity: climate.woongedeelte_radiator
            type: thermostat
          - entity: climate.slaapkamer_radiator
            type: thermostat
        type: horizontal-stack
      - entities:
          - entity: media_player.sonos
          - entity: media_player.speakers
          - entity: media_player.badkamer
          - entity: media_player.slaapkamer
        show_header_toggle: false
        title: Speakers
        type: entities
      - entities:
          - entity: media_player.samsung_tv
          - entity: media_player.slaapkamer_tv
        title: Tv's
        type: entities
      - entity: light.ventilator
        icon: 'mdi:fan'
        type: light
      - entities:
          - entity: switch.genie
          - entity: sensor.genie_perfume_name
          - entity: sensor.genie_perfume_level
          - entity: input_select.rituals_strength
          - entity: input_select.rituals_room_size
        title: Rituals Parfum Verdeler
        type: entities
      - entities:
          - entity: cover.alle
          - entity: cover.raam_links
          - entity: cover.raam_midden_links
          - entity: cover.raam_midden_rechts
          - entity: cover.raam_rechts
        title: Jaloezieën
        type: entities
      - entities:
          - entity: input_boolean.huisdeur_open
          - entity: input_boolean.huisdeur_slot
        title: Nuki
        type: entities
    icon: 'mdi:star'
    path: ''
    theme: ''
    title: Favoriet
  - badges: []
    cards:
      - entities:
          - entity: light.woongedeelte_lichten
          - entity: light.woonkamer_plafondlamp
          - entity: light.eetkamer_hanglamp_1
          - entity: light.eetkamer_hanglamp_2
          - entity: light.keuken_spot_2
          - entity: light.keuken_spot_1
          - entity: input_select.hue_scenes_woongedeelte
          - entity: input_select.extra_scenes_woongedeelte
        title: Woongedeelte
        type: entities
      - entities:
          - entity: light.slaapkamer_lichten
          - entity: light.slaapkamer_spot_1
          - entity: light.slaapkamer_spot_2
          - entity: light.slaapkamer_spot_3
          - entity: light.slaapkamer_spot_4
          - entity: input_select.hue_scenes_slaapkamer
        title: Slaapkamer
        type: entities
      - entities:
          - entity: light.badkamer_lichten
          - entity: light.badkamer_spot_1
          - entity: light.badkamer_spot_2
          - entity: light.badkamer_spot_3
          - entity: light.badkamer_spot_4
          - entity: light.badkamer_wandlamp
          - entity: input_select.hue_scenes_badkamer
        title: Badkamer
        type: entities
      - entities:
          - entity: light.eetkamer_lichten
          - entity: input_select.hue_scenes_eetkamer
        title: Eetkamer
        type: entities
      - entities:
          - entity: light.keuken_lichten
          - entity: input_select.hue_scenes_keuken
        title: Keuken
        type: entities
      - entities:
          - entity: light.woonkamer_lichten
          - entity: light.woonkamer_tv_lamp
          - entity: input_select.hue_scenes_woonkamer
        title: Woonkamer
        type: entities
      - entities:
          - entity: light.gang_lichten
          - entity: light.gang_spot_1
          - entity: light.gang_spot_2
          - entity: input_select.hue_scenes_gang
        title: Gang
        type: entities
    icon: 'mdi:lightbulb-group'
    path: lights
    theme: ''
    title: Lights
  - badges: []
    cards:
      - entities:
        title: Speakers
        type: entities
      - entities:
        title: Tv's
        type: entities
    icon: 'mdi:speaker'
    path: media
    title: Media
  - badges: []
    cards:
      - cards:
            type: thermostat
            type: thermostat
          - entity: climate.thermostaat
            type: thermostat
      - cards:
          - entities: null
            hold_action:
              action: more-info
            icon: 'mdi:fan'
            icon_height: 100px
            show_icon: true
            show_name: true
            show_state: false
            tap_action:
              action: toggle
            type: button
        type: 'custom:layout-card'
      - entities:
        type: entities
      - entities:
        title: Jaloezieën
        type: entities
    icon: 'mdi:home-thermometer'
    title: Climate
  - badges: []
    cards:
      - entities:
          - entity: switch.slaapkamer_sensor
          - entity: switch.badkamer_sensor
          - entity: switch.gang_sensor
        title: Beweging Sensoren
        type: entities
      - entities:
          - entity: binary_sensor.fire_4
          - entity: binary_sensor.fire_5
        title: Rookmelders
        type: entities
    icon: 'mdi:motion-sensor'
    title: Sensors
  - badges: []
    cards:
      - elements:
            style:
              left: 40%
              top: 30%
            type: state-badge
        image: 'https://demo.home-assistant.io/stub_config/floorplan.png'
        type: picture-elements
    path: kaarten
    title: Kaarten
raw config editor:
title: NiMa
  - badges: []
    cards:
      - entities:
        show_icon: true
        show_name: false
        show_state: true
        type: glance
      - entities:
        title: Buienalarm
        type: glance
      - entities:
        type: glance
        analogSize: 200px
        clockBold: false
        displayType: both
        secondsColor: red
        showDate: true
        showWeek: true
        timeFormat: 24
    title: Info
  - badges: []
    cards:
      - cards:
            type: thermostat
            type: thermostat
      - entities:
        title: Speakers
        type: entities
      - entities:
        title: Tv's
        type: entities
        icon: 'mdi:fan'
        type: light
      - entities:
        type: entities
      - entities:
        title: Jaloezieën
        type: entities
      - entities:
        title: Nuki
        type: entities
    icon: 'mdi:star'
    path: ''
    theme: ''
    title: Favoriet
  - badges: []
    cards:
      - entities:
        title: Woongedeelte
        type: entities
      - entities:
        title: Slaapkamer
        type: entities
      - entities:
        title: Badkamer
        type: entities
      - entities:
        title: Eetkamer
        type: entities
      - entities:
        title: Keuken
        type: entities
      - entities:
        title: Woonkamer
        type: entities
      - entities:
        title: Gang
        type: entities
    path: lights
    theme: ''
    title: Lights
  - badges: []
    cards:
      - entities:
          - entity: input_select.hue_groups
          - entity: script.set_hue_scene
        title: My Title
        type: entities
      - type: horizontal-stack
        cards:
          - type: 'custom:button-card'
            template: header
            name: My Test Header\
      - type: vertical-stack
        cards:
            cards:
                template: horizontal-filler
    icon: ''
    path: test
    title: test
  - badges: []
    cards:
      - entities:
        title: Speakers
        type: entities
      - entities:
        title: Tv's
        type: entities
    icon: 'mdi:speaker'
    path: media
    title: Media
  - badges: []
    cards:
      - cards:
            type: thermostat
            type: thermostat
            type: thermostat
      - cards:
          - entities: null
            hold_action:
              action: more-info
            icon: 'mdi:fan'
            icon_height: 100px
            show_icon: true
            show_name: true
            show_state: false
            tap_action:
              action: toggle
            type: button
      - entities:
        type: entities
      - entities:
        title: Jaloezieën
        type: entities
        state_color: true
    title: Climate
  - badges: []
    cards:
      - entities:
        type: entities
      - entities:
        title: Rookmelders
        type: entities
    title: Sensors
  - badges: []
    cards:
      - elements:
            style:
              left: 40%
              top: 30%
            type: state-badge
    path: kaarten
    title: Kaarten
only the part for the templates would have sufficed :wink: and an actual card in the config, please dont make us search your full config…
just to be sure, custom card buttons without a button_card_template doe work as expected? meaning the resource itself is loaded correctly
oh sorry, haha. Yep that works.
did you get a chance to take a look?
thought you were still in the process, sorry.
I am using yaml mode, so not experienced in raw editor. judging on your ui-lovelace.yaml the pointer to the button_card_templates: is fine.
what I cant find is where in the lovelace cards you use any of these templates? I see it referenced in the raw editor, but not in the ui-lovelace.yaml. Now I dont use raw UI config, but if you have the ui-lovelace.yaml, dont you use yaml mode?
Really hate the order of the raw config editor, and it would take some time to order that humanely readable…
yes I use the ui-lovelace.yaml, but I Just wanted to check if there was a difference. If I change something in my yaml file, then it doesn’t change anything in my view. This is the start of my config:
default_config:
homeassistant:
  customize: !include customize.yaml
  customize_glob: !include customize_glob.yaml
frontend:
  themes: !include_dir_merge_named themes
  extra_module_url:
    - lovelace/resources/custom-ui/custom-ui.js
lovelace:
  mode: yaml
  resources: !include lovelace/resources/resources.yaml
# Text to speech
tts:
  - platform: google_translate
    language: nl
#includes
group: !include includes/groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
light: !include includes/lights.yaml
switch: !include includes/switches.yaml
input_select: !include includes/inputselects.yaml
cover: !include includes/covers.yaml
that’s odd… changing the ui-lovelace.yaml, or any of its imports, should definitely change the view you see…
btw this:
  extra_module_url:
can safely be replace by adding the resource to your resources.yaml. (I like to have all resources in one placeholder…)
# https://github.com/Mariusthvdb/custom-ui
- url: /local/lovelace/resources/custom-ui/custom-ui.js?v=20200918
  type: module
dont want to make you mad, but:
you do refresh Lovelace after that don’t you…?
Well I restart home assistant every time now just in case
figured out why my view wasn’t updating. well I have a default view and another and the other one isn’t updating, but the default one is. But I still get the error that the templates are missing.
odd, they both should be updating on Lovelace refresh, no need to restart for that at all.
This does point to the issue though, and, solution. For both dashboards you need to declare the path to the button-card-templates.
example:
I have 3 dashboards and this is 1:
title: Ha Rpi4 Data
decluttering_templates: !include_dir_named lovelace/decluttering_templates
custom_header: !include lovelace/includes/custom_header_data.yaml
  - !include lovelace/views/view_Phones_tablets.yaml         #0
  - !include lovelace/views/view_Travel.yaml                 #1
  - !include lovelace/views/view_Home_climate.yaml           #2
  - !include lovelace/views/view_Summary_groups.yaml         #3
  - !include lovelace/views/view_Time_settings.yaml          #4
  - !include lovelace/views/view_Home_energy.yaml            #5
  - !include lovelace/views/view_Home_solar_energy.yaml      #6
  - !include lovelace/views/view_Computer_netwerk.yaml       #7
  - !include lovelace/views/view_Audio_video_gaming.yaml     #8
hope this helps.
