Hue-sensors - motions aren't showing temperature
Hello - I followed all of the steps outlined here: https://github.com/robmarkcole/Hue-sensors-HASS
Some of it is working. I can see the motions state of on or off. I can’t seem to get the temperature bit working.
I’ve made the config changes, but the temperature data doesn’t come up. See below - any ideas?
configuration.yaml
# Hue-sensors
hue:
  bridges:
    - host: 10.1.30.162
  - platform: hue
# Example template sensor
    sensors:
      Garage_Sensor_temperature:
      friendly_name: 'Garage temperature'
      value_template: '{{states.sensor.basement_hallway_garage_motion_sensor.attributes.temperature}}'
groups.yaml
default_view:
view: no
entities:
- group.Hue
- group.Garage_Light
- group.Lights
Garage_Light:
  entities:
    - sensor.basement_hallway_garage_motion_sensor_temperature
    - light.basement_hallway_garage
In mine they are motion_motion rather than motion_sensor, have you checked the attribute template in the dev panel?
Also your entries in your group don’t match the sensor names you’ve defined.
And finally, I think your name for the sensor has to be lowercase.
You mean the name of the sensor? Yes, in the dev panel it reads
I’m not following. All the names are the same. What am i not seeing?
Ok - changed that. Seems to have eliminated the config validation errors too.
Still not seeing it.
According to your paste your temperature sensor is called sensor.garage_sensor_temperature
But in your group you have
Hmmmm … I don’t have sensor.garage_sensor_temperature anywhere.
Do you mean
sensors:
garage_sensor_temperature:
That should go into groups.yaml like this
Garage_Light:
  entities:
    - garage_sensor_temperature
Cause that doesn’t work.
According to your opening post you do…
The group should be
Garage_Light:
  entities:
    - sensor.garage_sensor_temperature
Sorry - I didn’t realize that this name needed to be carried over into groups.yaml. Thank you for the patience - really appreciate it.
Did I mention I’m new to this all? :slight_smile:
So I made the change, but still no dice. I’m not receiving any errors in the config validation, but it does show up in the group view page.
Here is configuration.yaml
    sensors:
Here is groups.yaml
Garage_Light:
  entities:
Ha, no worries :smile:
In your dev panel do you see the sensor? Has HA randomly changed it’s name a bit (like adding an underscore to the end or something)??
The name of the sensor in the Entities section is
I don’t get it. All the naming is correct. I think the yaml formatting is correct. No spaces, etc.
No, the temperature sensor that you’ve created - is it there?
Just realised your spacing is out on the template sensor which probably doesn’t help, should be:
    sensors:
Ah-ha! It’s not there. So the sensor isn’t being created.
I corrected the spacing per your recommendation and now I just keep getting config validation errors.
I’m using Notepad++. I’m using the “Tab” key. I don’t know what else to try to get the config syntax lined up right.
At least we know what the problem is. Thank you for the helping figure that out!
I even used this site: http://www.yamllint.com/ But it still doesn’t seem to give the correct output/syntax.
Delete the tabs and use spaces, 2 spaces before the hyphen on line 1, 4 spaces before sensors on line 2, 6 before garage on line 3 and 8 before the last 2 lines.
Wow - this is pretty frustrating. It’s either the statement or the formatting and I can’t tell which one is the problem.
What’s the error message?
The config validation returns
Configuration Validation
Validate your configuration if you recently made some changes to your configuration and want to make sure that it is all valid.
Configuration invalid.CHECK CONFIG
Testing configuration at /config
2018-01-24 15:59:02 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
  in "/config/configuration.yaml", line 1, column 1
expected <block end>, but found '-'
  in "/config/configuration.yaml", line 97, column 1
2018-01-24 15:59:02 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
Line 97 begins as:
   sensors:
        friendly_name: "Garage temperature"
        unit_of-measurement: °F
        value_template: "{{states.sensor.basement_hallway_garage_motion_sensor.attributes.temperature}}"
Should be unit_of_measurement not unit_of-measurement. That’s the - it’s complaining of.
Thanks - fixed.
I’m having no luck. No matter what I do, it appears that it associates itself with the previous line and the error like below persists
2018-01-24 17:16:09 ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
in “/config/configuration.yaml”, line 1, column 1
expected , but found ‘’
in “/config/configuration.yaml”, line 95, column 2
2018-01-24 17:16:09 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
These are the lines
89 - 101
# Hue-sensors
hue:
bridges:
- host: 10.1.30.162
- platform: hue
    sensors:
        unit_of_measurement: °F
I think you are going to have to post your whole configuration.yaml in a code block (with any passwords redacted) so we can get your indentations and quotes correct tbh.
You need to post in code blocks so we can check spacing. Make sure there are no tabs, only spaces.
