Hey all, big time newb here (first post) – so far I’ve been learning so much about HA and can’t get enough of it. I’m moving over from hubitat. One big thing that I see that’s missing is the Hue Sync Box controls.
Doing a quick search it looks like some discussion was had about the API, but not much came from it.
I noticed that someone wrote a Hubitat driver for it, I’m not at all someone who is capable of understanding what goes into a driver. Does anyone think we can make a HA integration based off some of this code?
From this thread:
The link to the repository seems to be broken, so I’ve pasted the code from my Hubitat instance to here.
* Copyright Daniel Terryn
* Name: Driver to communicate with Hue Sync Box....
* Date: 2020-02-07
* Version: 1.20
* Author: Daniel Terryn
* Description: A driver to retrieve to control the Hue Sync Box....
* License:
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
* 2020-02-07 Daniel Terryn Original Creation
* 2020-02-26 Daniel Terryn Added reboot command, fixed Input 4
metadata {
definition (name: "Hue Sync Box", author: "dan.t", namespace: "dan.t", importUrl: "https://raw.githubusercontent.com/danTapps/Hubitat/master/Drivers/Hue%20Sync%20Box/hue_sync_box.groovy") {
capability "Refresh"
capability "Switch"
capability "Initialize"
capability "Presence Sensor"
command "setMode", [[name:"Set Mode*", type: "ENUM", description: "Set Mode", constraints: ["passthrough", "video", "music", "game"] ] ]
command "setInput", [[name:"Set Input*", type: "ENUM", description: "Set Input", constraints: ["input1", "input2", "input3", "input4"] ] ]
command "setItensity", [[name:"Mode*", type: "ENUM", description: "Mode", constraints: ["video", "music", "game"] ],[name:"Intensity*", type: "ENUM", description: "Intensity", constraints: ["subtle", "moderate", "high", "intense"] ] ]
//command "toggleMode"
command "checkForUpdates"
command "reboot"
command "registerHueSyncBox"
attribute "brightness", "number"
attribute "mode", "string"
attribute "hdmiSource", "string"
attribute "lastSyncMode", "string"
attribute "firmwareVersion", "string"
attribute "lastCheckedUpdate", "string"
attribute "updateAvailable", "string"
attribute "intensity", "string"
preferences {
input ( name: "ip", type: "text", title: "HUE Sync Box IP Address", description: "IP Address in form 192.168.1.226", required: true, displayDuringSetup: true )
input ( name: "api_key", type: "text", title: "API Key", required: false, displayDuringSetup: true )
input ( name: 'pollInterval', type: 'enum', title: 'Update interval (in seconds)', options: ['10', '30', '60', '300'], required: true, displayDuringSetup: true, defaultValue: "60" )
input ( name: "configLoggingLevelIDE", title: "IDE Live Logging Level:\nMessages with this level and higher will be logged to the IDE.", type: "enum",
options: [
"0" : "None",
"1" : "Error",
"2" : "Warning",
"3" : "Info",
"4" : "Debug",
"5" : "Trace"
defaultValue: "3", displayDuringSetup: true, required: false )
def installed() {
logger("Executing 'installed()'", "info")
initialize()
def initialize() {
logger("Executing 'initialize()'", "debug")
updated()
def updated() {
logger("Executing 'updated()'", "debug")
configure()
state.authTryCount = 0
def configure() {
logger("Executing 'configure()'", "info")
state.loggingLevelIDE = (settings.configLoggingLevelIDE) ? settings.configLoggingLevelIDE.toInteger() : 3
unschedule()
def pollInt = settings["pollInterval"]?.toInteger()
// If change polling options in UI, may need to modify some of these cases:
switch (pollInt ?: 0) {
case 0:
logger("Polling disabled; not scheduling")
break
case 1..59:
logger("Scheduling polling every ${pollInt} seconds")
schedule("${Math.round(Math.random() * pollInt)}/${pollInt} * * ? * * *", "refresh")
break
case 60..259:
logger("Scheduling polling every 1 minute")
runEvery1Minute("refresh")
break
case 300..1800:
logger("Schedulig polling every 5 minutes")
runEvery5Minutes("refresh")
break
default:
logger("Scheduling polling every hour")
runEvery1Hour("refresh")
refresh()
def registerHueSyncBox()
if (settings.api_key != null) {
log.error "Hue Sync Box is already regsitered, please clear the API key setting to re-register your sync box"
return
if (settings.ip == null) {
log.error "Hue Sync Box IP has to be set"
return
if (state.authTryCount > 19) {
log.debug "I tried 20 times to register, I quit now. Check your settings."
return
log.debug "Running registration, press the power button for 2 seconds on the Hue Sync Box and make sure the TV is on, attempt ${state.authTryCount+1}"
unschedule()
def body = [:]
body.appName = "HueSyncBoxDriver"
body.instanceName = "HueSyncBoxDriver"
body.appSecret = "MTIzNDU2Nzg5MDEyMzQ1Njc4OTAxMjM0NTY3ODkwMTI="
def requestParams =
uri: "https://${settings["ip"]}/api/v1/registrations",
contentType: "application/json",
ignoreSSLIssues: true,
body : toJson(body)
try{
httpPost(requestParams)
response ->
if (response?.status == 200)
if (response?.data?.accessToken) {
device.updateSetting("api_key", [value:response?.data?.accessToken, type:"text"])
configure()
else {
log.error("Unknown error adding Hue Sync Box ${response?.data}")
runIn(10, "registerHueSyncBox")
state.authTryCount = state.authTryCount + 1
else
log.error "Error in registration Response ${response?.status}"
} catch (groovyx.net.http.HttpResponseException hre) {
log.error "Error:${hre.getResponse()?.getData()}"
} catch (Exception e) {
log.error "Something went wrong when posting: ${e}"
private sendUsernameRequest() {
def userDesc = "HueSyncBox"
def body = [:]
body.appName = userDesc
body.instanceName = userDesc
def requestParams =
uri: "https://${settings["syncBoxIP"]}/api/v1/registrations",
body : toJson(body)
//asynchttpPost("parseUsernameResponse", requestParams)
log.debug "${requestParams}"
try{
response ->
state["accessToken"] = response?.data?.accessToken
state["syncBoxAuthorized"] = true
else {
else
def refresh() {
if (settings.api_key == null) {
log.error "Hue Sync Box is not registered, please register the Hue Sync Box with the registration flow"
return
log.error "Hue Sync Box IP is not set, please updated your setting"
return
logger("Executing 'refresh()'", "debug")
try{
def data = sendAsyncHttpGet("")
def switchState = "off"
if (data?.execution?.syncActive == true) {
switchState = "on"
if (data?.execution?.mode)
if (data?.execution[data?.execution?.mode]?.intensity)
valueChangeEvent("intensity", data?.execution[data?.execution?.mode]?.intensity, "")
} else {
valueChangeEvent("intensity", "off", "")
valueChangeEvent("switch", switchState, "")
if (data?.execution?.brightness)
valueChangeEvent("brightness", data?.execution?.brightness, "")
valueChangeEvent("mode", data?.execution?.mode, "")
if (data?.execution?.hdmiSource)
valueChangeEvent("hdmiSource", data?.execution?.hdmiSource, "")
if (data?.execution?.lastSyncMode)
valueChangeEvent("lastSyncMode", data?.execution?.lastSyncMode, "")
if (data?.device?.firmwareVersion)
valueChangeEvent("firmwareVersion", data?.device?.firmwareVersion, "")
if (data?.device?.lastCheckedUpdate)
valueChangeEvent("lastCheckedUpdate", data?.device?.lastCheckedUpdate, "")
if (data?.device?.updatableFirmwareVersion)
valueChangeEvent("updateAvailable", "true", "")
else
valueChangeEvent("updateAvailable", "false", "")
valueChangeEvent("presence", "present", "")
} catch (Exception e){
logger("refresh() exception ${e}", "error")
valueChangeEvent("presence", "not present", "")
def toggleMode()
try{
def currentMode = state?.data_points["mode"]
setMode(state?.data_points["lastSyncMode"])
valueChangeEvent("lastSyncMode", currentMode, "")
logger("toggleMode() exception ${e}", "error")
def checkForUpdates()
try{
sendAsyncHttpPut("/device", "{\"action\": \"checkForFirmwareUpdates\" }")
logger("checkForUpdates() exception ${e}", "error")
def reboot()
runActionCmd("doSoftwareRestart")
def setInput(input)
logger("Receive \"setInput(\"${input}\")\" command", "info")
try{
sendAsyncHttpPut("/execution", "{\"hdmiSource\":\"${input}\"}")
valueChangeEvent("hdmiSource", input, "")
logger("setInput() exception ${e}", "error")
def setMode(mode)
logger("Receive \"setMode(\"${mode}\")\" command", "info")
try{
sendAsyncHttpPut("/execution", "{\"mode\": \"${mode}\"}")
valueChangeEvent("mode", mode, "")
if (mode == "passthrough")
valueChangeEvent("intensity", "", "")
logger("setMode() exception ${e}", "error")
def setItensity(mode, intensity)
logger("Receive \"setItensity(\"${mode}\", \"${intensity}\")\" command", "info")
try{
sendAsyncHttpPut("/execution", "{\"${mode}\":{ \"intensity\": \"${intensity}\"}}")
valueChangeEvent("intensity", intensity, "")
logger("setItensity() exception ${e}", "error")
def on() {
logger("Receive \"on()\" command", "info")
try{
setMode("video")
valueChangeEvent("switch", "on", "")
logger("on() exception ${e}", "error")
def off() {
logger("Receive \"off()\" command", "info")
try{
setMode("passthrough")
valueChangeEvent("switch", "off", "")
logger("off() exception ${e}", "error")
def valueChangeEvent(def deviceAttribute, def newValue, def newUnit = "")
def success = false
def oldValue = null
if (newValue == null)
return false
if (state?.data_points)
if (state?.data_points["${deviceAttribute}"])
oldValue = state?.data_points["${deviceAttribute}"]
if (state?.data_points["${deviceAttribute}"] == newValue)
return false
else if (state?.data_points["${deviceAttribute}"].toString().equals(newValue.toString()))
return false
else
state.data_points = [:]
state.data_points["${deviceAttribute}"] = newValue
logger("Send new ${deviceAttribute} state, old: ${oldValue}, new: ${newValue}", "info")
def descriptionText = "${device.displayName} ${deviceAttribute} is ${newValue}"
sendEvent(name: deviceAttribute, value: newValue, unit: newUnit, descriptionText: descriptionText)
return true;
def sendAsyncHttpPut(message, body)
def requestParams =
uri: "https://${settings.ip}/api/v1"+message,
headers: ["Authorization": "Bearer ${settings.api_key}"],
timeout: 200,
body : body
logger("sendAsyncHttpPut: ${requestParams}", "debug")
try{
httpPut(requestParams) //change to httpGet for the get test.
response ->
logger(response.data, "debug")
return response.data
else
logger("httpPut ${response?.status}", "warn")
} catch (org.apache.http.conn.HttpHostConnectException e) {
logger("httpPut HttpHostConnectException ${e}", "error")
} catch (org.apache.http.NoHttpResponseException e) {
logger("httpPut NoHttpResponseException ${e}", "error")
logger("httpPut Exception ${e}", "error")
def sendAsyncHttpGet(message)
def result = null
def requestParams =
timeout: 200,
logger("sendAsyncHttpGet: ${requestParams}", "debug")
try{
httpGet(requestParams) //change to httpGet for the get test.
response ->
result = response.data
else
log.warn "${response?.status}"
logger("httpGet HttpHostConnectException ${e}", "error")
logger("httpGet NoHttpResponseException ${e}", "error")
logger("httpGet Exception ${e}", "error")
return result
* logger()
* Wrapper function for all logging.
private logger(msg, level = "debug") {
switch(level) {
case "error":
if (state.loggingLevelIDE >= 1) log.error msg
break
case "warn":
if (state.loggingLevelIDE >= 2) log.warn msg
break
case "info":
if (state.loggingLevelIDE >= 3) log.info msg
break
case "debug":
if (state.loggingLevelIDE >= 4) log.debug msg
break
case "trace":
if (state.loggingLevelIDE >= 5) log.trace msg
break
default:
log.debug msg
break
def toJson(Map m)
return new groovy.json.JsonBuilder(m).toString()
