Hue Sync + Hyperion (over Home Assistant and DIYHue)
Hello together,
my name ist Michael, this is my first post here so greetings to you all :).
I have a very specific problem and i hope someone here can help me because i am out of ideas.
My goal:
Use Hue Sync to control my normal hue bulbs AND my hyperion LEDs to react to music.
What i have done:
I installed Home Assistant, because there is a integration for hyperion. Then i installed the HA-Addon DIYHue. In DIYHue i can import the hyperion LEDs over HA as a hue light. The original HUE Bulbs are imported over the normal hue-bridge.
Now i am able to connect with the hue app to DIYHue an i can see all 3 LEDs and can control them. Set light colors, activates scenes, everything works fine. Then i created a entertainment area for all 3 leds. Now i use a third party app which can listen to music and control the 3 leds in the entertainment area.
Problem:
The normal HUE Bulbs reacts perfectly to the music. But the hyperion LED only switches the color every 5-10 seconds. I also can see in HA, that there ist only a color switch every 5-10 seconds.
If i control the LED Colors of the hyperion leds over the hue app, the reaction time is nearly without any delay. So in theory, there is a way to get this to work. Maybe there are some special hue color transition commands that HA can not process by default and only full color commands are working. I have no idea, but i hope someone here can point me in the right direction.
Greetings and Thanks in Advance,
Michael
@NRGizzer Did you ever figure this out?
