Hue Tap Dial (For native Hue integration)
This the first blueprint I’ve written and I’m excited to share it with the community. I hope I’ve followed the steps correctly to share. Apologies in advance for any errors.
Context: None of the existing blueprints work with the native Hue integration in home assistant but are rather for ZHA or other zigbee integrations. I wanted to create one for the native Hue integration. Further this one uses the actual dial rotary values so that it feels more responsive to fast vs slow rotations.
Application: Use Hue Tap Dial Switch to control 1 speaker and 3 lights.
Use: Tap Once to select a device. Then the dial can be used to control brightness or volume of the device. Long press to toggle the device.
Requirements: A Hue Tap Dial switch, media player, and 3 lights. You will also need to create an input_text helper.
Credits: Credit to u/silashansen and u/Jannik_Wagner for inspiration and code examples. Credit to the community for helping me quickly get up to speed on templating.
https://gist.github.com/sundar2012/4b143d245b073d2f58bcb0c2aa2ecf5d
Full YAML below:
blueprint:
  name: Philips Hue Tap Dial Audio + Light
  description: Use the Philips Hue Tap Dial to control speakers and lights, volume and brightness.  Long press to toggle play/pause on/off.  Short press to select device for dial use.
  domain: automation
  input:
    tap_dial:
      description: The tap dial to use.  just select the battery sensor that is exposed
      selector:
        entity:
          multiple: false
          filter:
            - domain: sensor
              integration: hue
    media_controller:
      name: media player device for button 1
      description: The media player for Button 1.  Long Press will play/pause.  Short press will allow you to control volume with the dial.
      selector:
        entity:
          multiple: false
          filter:
            - domain:
                - media_player
    light_button2:
      name: Light for button 2
      description: The light for Button 2.  Long Press will toggle the light.  Short press will allow you to control brightness with the dial.
      selector:
        entity:
          multiple: false
          filter:
            - domain:
                - light
    light_button3:
      description: The light for Button 3.  Long Press will toggle the light.  Short press will allow you to control brightness with the dial.
      selector:
        entity:
          multiple: false
          filter:
            - domain:
                - light
    light_button4:
      name: Light for button 4
      description: The light for Button 4.  Long Press will toggle the light.  Short press will allow you to control brightness with the dial.
      selector:
        entity:
          multiple: false
          filter:
            - domain:
                - light
    helper_input:
      description: You will need to create an input_text helper for this blueprint.  Select it here.
      selector:
        entity:
          multiple: false
          filter:
            - domain:
                - input_text
variables:
  tap_dial_used: !input tap_dial
  controller: !input media_controller
  light_button2: !input light_button2
  light_button3: !input light_button3
  light_button4: !input light_button4
  helper_input: !input helper_input
mode: parallel
  - platform: event
    event_type: hue_event
condition:
  - condition: template
    value_template: >-
      {{trigger.event.data.device_id == device_id(tap_dial_used)}}
  - variables:
      action: "{{ trigger.event.data.type }}"
      action_sub: "{{ trigger.event.data.subtype }}"
      action_steps: "{{ trigger.event.data.steps }}"
  - choose:
      - conditions:
            value_template: "{{ action == 'short_release' }}"
        sequence:
          - choose:
              - conditions:
                    value_template: "{{ action_sub == 1 }}"
                sequence:
                  - service: input_text.set_value
                    metadata: {}
                      value: !input media_controller
                      entity_id: !input helper_input
              - conditions:
                    value_template: "{{ action_sub == 2 }}"
                sequence:
                    metadata: {}
                      value: !input light_button2
              - conditions:
                    value_template: "{{ action_sub == 3 }}"
                sequence:
                    metadata: {}
                      value: !input light_button3
              - conditions:
                    value_template: "{{ action_sub == 4 }}"
                sequence:
                    metadata: {}
                      value: !input light_button4
      - conditions:
            value_template: "{{ action == 'long_press' }}"
        sequence:
          - choose:
              - conditions:
                sequence:
                  - service: media_player.media_play_pause
                    metadata: {}
                      entity_id: !input media_controller
                    data: {}
              - conditions:
                sequence:
                  - service: light.toggle
                    metadata: {}
                      entity_id: !input light_button2
                    data: {}
              - conditions:
                sequence:
                    metadata: {}
                      entity_id: !input light_button3
                    data: {}
              - conditions:
                sequence:
                    metadata: {}
                      entity_id: !input light_button4
                    data: {}
      - conditions:
            value_template: "{{ action_sub == 'clock_wise' }}"
        sequence:
          - if:
                value_template: "{{ states(helper_input)[:5] == 'media'}}"
            then:
              - service: media_player.volume_set
                metadata: {}
                  volume_level: >-
                    {{state_attr(states(helper_input),
                    'volume_level') + (trigger.event.data.steps / 1500)}}
            else:
              - service: light.turn_on
                metadata: {}
                  brightness_step_pct: "{{ (trigger.event.data.steps / 1500)* 100 }}"
                  entity_id: "{{ states(helper_input) }}"
      - conditions:
            value_template: "{{ action_sub == 'counter_clock_wise' }}"
        sequence:
          - if:
            then:
                metadata: {}
                  volume_level: >-
                    'volume_level') - (trigger.event.data.steps / 1500)}}
            else:
                metadata: {}
                  brightness_step_pct: "{{ (trigger.event.data.steps / 1500)* -100 }}"
max: 15
Very nice, thank you
How well does the dimming work for you? For me it’s quite slow to react and the brightness jolts in steps, whereas when configured via the Hue app, it’s quite smooth, reacts more quickly, and if I turn the dial a reasonable turn in one go, it will just increase the lights directly to that brightness, instead of jumping up in lots of visible steps.
This is great, works as expected thanks!. If possible, could it allow for any combination of 4 lights or media_players instead of always 1 media_player and 1 light.
Thanks for this, very useful.
Same problem for me.
Have You got a solution since your post ?
I stopped using the native Hue integration and moved everything to zigbee2mqtt, plus Switch Manager for all switches. It supports the Tap Dial via zigbee2mqtt but also via the native Hue integration by the looks of it, so you could perhaps try it out.
I can’t remember exactly what the dimming was like via Hue - for me now, it’s not instantaneous but is smooth and good enough, and my current setup means I no longer need the Hue bridge, app, or integration and can configure all my switches of different types in one place without needing different blueprints and automations.
This is very cool…
But in my use case it’s a simpler use of the Tap Dial Switch. The whole device will be controlling lights in a single room – each button will select a pre-determined scene, four in total, the rotary will act as a dimmer regardless which scene is selected. The idea of “select one from four and control it” is very cool but not what I need on this occasion.
Is this integration still my best bet? I don’t want to try to force-fit a piece of great code to the wrong use case… worst of all worlds.
Thanks!
Alastair
