I try to set up automation that does the following:
When a certain scene for HUE is activated (either through the Hue App or HA) I want to play a certain music. Casting to Chromecast is not a problem, but what is the trigger I need to use. When I trace the commands with dev-tools I get a different ID every time.
You can use Event Triggers to detect when Home Assistant is used to activate a Hue scene. Here’s a simple automation that reports the entity_id of the scene that was activated. There’s more than one way to turn on a scene in Home Assistant so that’s why the automation has two Event Triggers.
When you use the Philips Hue app to turn on a Hue scene, Home Assistant does not detect the scene activation as a special event. It simply detects the state-changes of each light in the scene.
NOTE
The second Event Trigger listens for any scene activation, not just Hue scenes.
I just tried to use your (tara’s) code and in result, the automation was triggered in case of activating the scene via Home Assistant Dashboard. But activating the scene via the Hue app on my mobile does not trigger. Also when activation is made by voice command to alexa (which is also going to the hue bridge) it does not trigger the HA automation. I have no clue at the moment, where I could have masde a mistake. Any hints, maybe?
I found this thread while trying to detect a Hue scene being fired by Hue, and @123 actually gives the answer above, i.e. it’s not possible:
That said, you can detect the hue switches at least, so that is an option, just not a great one because you can’t tell which scene was just activated; you’d have to keep track of the theoretical scene based on your Hue logic.
For example, I have a Hue switch that cycles through 7 scenes with each press, so I would have to make an input_select to contain the scenes and do a select_next each time the button is pressed. And deal with the off/on resetting the list to the first one each time. And deal with the fact that it will probably get out of sync with power outages etc. A lot of work to just get the last fired scene, and probably not worth it.
