I’m trying to get the new Hue Wall Switch Module to work in Homeassistant, so I can replace the 433 MHz units currently in use.
The 2 Switches of a single Hue Wall Switch are not showing up in the developer tools, the battery state of that unit does.
I’m not using Deconz as suggested in another post, because the Hue integration page states that the Hue Wall Switch Module is supported and I’m using the standard Hue bridge for integration, not a 3rd party Zigbee product.
Any one having tips on how to configure the Hue Wall Switch Module?
Setup an automation using the UI. The device ‘ Hue wall switch module 1’ is there to select, but strangely only the trigger ‘“First button” release’ and ‘“Second button” release’ are shown. So it is only possible to trigger one action like switching off a lamp, not to switch it on.
So I have to rely on YAML code for automation. Where did you source the Device ID (GUID?) in your example code?
