Hue wall switch module: not working correctly using Hue integration
Today all triggers that a Hue wall switch module produces are available for automations.
Test the working gave unexpected results.
Configuration:
Hue: default settings, ‘configure using other app’
Home Assistant: using the UI, created 2 automations: one to switch a light on and one to switch it off
Using short press/release trigger:
The action to turn on a light is processed and the light goes on, but is turned off immediately
In the automation configuration using the UI, a trigger indication is shown for the on and the off automation when the rocker switch is switched
Conclusion: the on trigger is processed, but triggers the off automation as well. This is incorrect causing the light to switch off immediately. Removing the switch off automation leaves the light switched on.
Using button held down/release trigger:
No action is performed.
In the automation configuration using the UI, a trigger indication is not shown on the on and the off automation
Additional info: looking at the UI for the off automation while handling the rocker switch: a trigger indication is shown on both the on and off trigger if configured for ‘release after short press’
Did anybody succeed in getting this to work properly?
Regards
OWK
