Can a Hue White and Color Ambiance Play Light Bar be integrated w HA ?
I currently use a HUSBZB-1 to connect Philips Hue bulbs.
As far as I know these are zigbee lights, so they should work.
How would I detect it ?
Configuration --> Integration --> Zigbee Home Automation —> Configure —> Add Device ???
Does it have a pairing mode on the light bar ?
You can reset the bulb by using a Hue Dimmer Switch and holding it close to the bulb and press the ON and OFF buton for approx. 10 seconds, the light should start to blink and when it stops blinking it has been reset. About ZHA, I don’t know I use something else.
