I’ve seen people mention they can get hue apps to work with conbee.
How are you doing that? I can’t get apps to recognize any other bridge than Phillips own.
Is there some magic trick ?
I am not aware that the hue app can work with conbee. However you can have home assistant talk to hue lamps via conbee.
Yes I got homeassistant connected already. That part is all good.
I’ve seen several forum posts and web mentions on conbee showing up as a bridge to use with other apps.
And the app in particular I really need is huedisco as my kids keep asking why I cant make the kitchen lights change color to the music anymore
Got issue open with more info starting it should work but require port 80 for most apps.
https://github.com/dresden-elektronik/deconz-rest-plugin/issues/1006
turns out if you just update the port in conbee hassio addon to 80 then hue apps can connect - yay!
