This project uses WiFi sensing (through-wall human activity recognition) between one esp32 and a router. Project uses CSI (Channel State Information) to detect human activity. It exposes a binary sensor to HA.
this sounds neat, can it detect more then one person?
theoretically, it could, with multiple boards separated by some distance with non-overlapping detection zones.
Thanks, this looks interesting just some questions
- From some demo i’ve seen it seems to only detect movement but not when you’re idle?
- How do you position the esp in a room? Do you need more than one and is there any additional setup needed so it’s specific to a room and doesn’t overlap?
@mzakharo Is there a reason why you removed this code from Github? I am using it, but get an error now every time I try to update via esphome ![]()
Hello, I would like to contact you. I need the project.
maybe this can help?
reading helps
