This is my first Blueprint. I created this after i could not find an easy to use Humidity controller.
This turns a device (like a switch or fan) on or off based on a humidity sensor’s reading. Uses separate on/off thresholds to prevent rapid cycling. Also monitors manual overrides and adjusts based on current humidity conditions.
If your comment is regarding the Generic Hygrostat… For that, you would just set up an automation that turns it off during the desired time span.
If you meant to respond to OP… Once you fill out all the fields of the blueprint, you can then take control of the automation and add a Time condition.
