Hello
Sorry for the bad English.
I have a sonoff relay, a motion sensor and a door open sensor, as well as a humidity meter.
I would like to resolve that if the humidity is higher than 76 percent, turn on the sonoff relay. Also … If the door is open, turn it off. This has been resolved so far, but something is still needed.
If motion is detected, still turn off the relay and if not, but the humidity is above 76, turn it back on. Unfortunately, this part is not going. How could this be solved?
First automation. If the humidity is low.
alias: Alacsony a pára
description: ‘’
- type: humidity
platform: device
device_id: c4b5b57809c8b4c7a5a4cac1160fad2b
entity_id: sensor.lumi_lumi_sens_f7ae8304_humidity
domain: sensor
above: 0
below: 76
condition: []
action: - service: sonoff.send_command
device: 1000c2059d
switch: ‘off’
mode: single
Second. If the humidity is high.
alias: Magas a pára
description: ‘’
trigger: - type: humidity
platform: device
domain: sensor
above: 76
condition: []
device: 1000c2059d
switch: ‘on’
mode: single
Third. When the door is open.
alias: Nyitva az ajtó
description: ‘’
- type: opened
platform: device
device_id: 47fb5d442140bd6d36280841062f91c0
entity_id: binary_sensor.lumi_lumi_sensor_magnet_2b6f5a04_on_off
domain: binary_sensor
condition: - condition: and
conditions:- condition: state
entity_id: switch.sonoff_1000c2059d
state: ‘on’
- condition: state
device: 1000c2059d
switch: ‘off’
mode: single
Fourth. If the door is closed.
alias: Zárva az ajtó
description: ‘’
- type: not_opened
platform: device
state: ‘off’ - condition: and
conditions:- type: is_humidity
condition: device
domain: sensor
above: 76
- type: is_humidity
- condition: state
device: 1000c2059d
switch: ‘on’
mode: single
I’m here for now. If I also install the motion sensor, it will not work.
