Humidity Sensor Recommendations
I am looking for recommendations for a humidity sensor that doesn’t require another hub.
I have a Z-Wave stick, Hue Bridge, Energenie MIHO001 Gateway and will likely have a Somfy hub soon for my blinds, if any humidity sensors could link into any of these (or Wifi) then that would be perfect.
Looking for something that easily integrates into HA and is accurate.
Dan
I’d replace the Hue Bridge with some generic ZigBee stick such as ConBee II and get some ZigBee sensors such as the Xiaomi Temp/Humidity sensors.
I would recommend the same!
The Hue Bridge is only needed if you want to use hue entertainment.
For the most lights and sensors I use the Conbee 2 Stick, for lights in my living Room I use the Hue bridge.
