Hi folks,
I just bought some humidity sensors, and they are working … now I want to add them to my dashboard. And therefore I try to adjust a script which I found for my lights:
{% set lights = [
states.light.licht_bad_keller,
states.light.schlafzimmer,
states.light.licht_kuche,
states.light.licht_esszimmer,
states.switch.verstarker,
states.switch.licht_flur_eg,
states.switch.licht_og,
states.light.licht_windfang,
states.light.licht_wohnzimmer,
states.switch.stehlampe,
states.light.licht_paula,
states.light.licht_ben,
states.light.ben_lightstrip,
states.light.licht_phil,
states.switch.waschkuche_switch_0,
states.switch.smart_switch_2211026018474458080148e1e9af4919_outlet,
states.switch.smart_switch_2211027228081558080148e1e9af3423_outlet, states.switch.smart_plug_20010836349749251h3148e1e91651fd_outlet,
states.light.shapes_49a7,
{% set devices = [
{% set lights_on = lights | selectattr('state','eq','on') | list %}
{% set lights_name = lights | selectattr('state','eq','on') | map(attribute='name') | join(', ') %}
{% set devices_on = devices | selectattr('state','search','(close|closed)') | list %}
{% set devices_name = devices_on | map(attribute='name') | join(', ') %}
{% if (lights_on | length == 0) and (devices_on | length > 0) %}
{{ devices_name | regex_replace(',([^,]*)$',' och\\1') }} ist eingeschaltet
{% elif (lights_on | length == 1) and (devices_on | length == 1) %}
{{ lights_name }} und {{devices_name }} ist eingeschaltet
{% elif (lights_on | length == 1) and (devices_on | length > 1) %}
{{ lights_name }}, {{ devices_name | regex_replace(',([^,]*)$',' och\\1') }} ist eingeschaltet
{% elif (lights_on | length > 1) and (devices_on | length == 1) %}
{{ lights_on | length }} Lampen und {{ devices_name }} sind eingeschaltet
{% elif (lights_on | length > 1) and (devices_on | length > 1) %}
{{ lights_on | length }} Lampen, {{ devices_name | regex_replace(',([^,]*)$',' och\\1') }} sind eingeschaltet
{% elif (lights_on | length == 1) and (devices_on | length == 0) %}
{{ lights_name }} ist eingeschaltet
{% elif (lights_on | length > 1) and (devices_on | length == 0) %}
{{ lights_on | length }} Lampen sind eingeschaltet
{% else %}
<font color='#ffffff'>Alle Lichter sind ausgeschaltet</font>
{% endif %}
What I want to do is like that:
{% set sensor = [
states.sensor.temperatur_schlafzimmer_1_humidity_sensor,
{% set devices = [
{% set sensor_wet = sensor | selectattr('state','eq','60') | list %}
{% set sensor_name = sensor | selectattr('state','eq','60') | map(attribute='name') | join(', ') %}
{% set devices_on = devices | selectattr('state' > 60') | list %}
{% if (sensor_wet | length == 0) and (devices_on | length > 0) %}
{{ devices_name | regex_replace(',([^,]*)$',' och\\1') }} appears to be damp
Can anybody help me here… ?
Cheers
