My first try to use an automation:
- id: '1613935335031'
alias: Luftfeuchtigkeit niedrig
description: ''
- type: humidity
platform: device
device_id: f3881f6438b3685f4eff3d55f899c8b6
entity_id: sensor.unk_manufacturer_unk_model_b2bd6c22_humidity
domain: sensor
below: 50
condition:
- below: 50
condition: numeric_state
- service: light.turn_on
entity_id: light.tz3000_dbou1ap4_ts0505a_level_light_color_on_off
brightness: 255
rgb_color: 255, 255, 0
The Action is not triggered. Humidity is 45% at the moment. To my understanding the light should turn on and be on full brightness at rgb 255,255,0
Instead the light turns off as soon as I trigger the automation manually.
m0wlheld
(Christoph Dahlen)
February 21, 2021, 8:06pm
2
description: ''
- platform: numeric_state
below: 50
condition: []
brightness: 255
It still ignores the RGB color. The manual control is no problem.
m0wlheld
(Christoph Dahlen)
February 21, 2021, 9:08pm
4
From the docs of `light.turn’ for parameter rgb_color:
A list containing three integers between 0 and 255 representing the RGB color you want the light to be. Three comma-separated integers that represent the color in RGB, within square brackets. Note that the specified RGB value will not change the light brightness, only the color.
So, it‘s
rgb_color: [255,255,0]
or
rgb_color:
- 255
- 255
- 0
metbril
(Robert 🇳🇱🇪🇺)
February 22, 2021, 5:28am
5
The automaton is triggered when humidity drops below 50%. Since it’s already below that threshold it will not trigger.
For testing purposes you could replace the sensor with an input_number helper and play with it.
Thanks for your answers. Let’s say I would change the color for every 10% increase or decrease of humidity, do I have to make 10 different automation rules? Or can I combine it?
metbril
(Robert 🇳🇱🇪🇺)
February 22, 2021, 6:46am
7
You could basically use one automation with some templates for the colors.
But how can I define the ranges in the automation? In the GUI I can set only a condition.
m0wlheld
(Christoph Dahlen)
February 22, 2021, 11:09am
9
try this (not sure, if it will work)
rgb_color:
- "{{ states('sensor.unk_manufacturer_unk_model_b2bd6c22_humidity') | int / 100.0 * 255 }}"
- 255
- 0
If templating works for red, then you can copy this to the remaining color channels.
thanks this helped. The only thing is that the trigger does not execute it:
To my understanding it should trigger on every change of the temperature (I am now using temp instead of humidity).
But it doesn’t
I have to press execute and watch the color change.
m0wlheld
(Christoph Dahlen)
February 22, 2021, 1:44pm
11
No, it only triggers if the above or below thresholds are crossed.
Ok thanks I see.
The “state” trigger should fire on every value change?
m0wlheld
(Christoph Dahlen)
February 22, 2021, 2:48pm
13
This will only trigger, if state changes from “0” to “100”. Remove From and To arguments and it will trigger on every state change.
