I’m running HomeAssistant on a RasPi 3. I’m only in week 2 so bear with me.
I can’t boot correctly with my HUSBZB-1 USB stick plugged in (Zwave and Zigbee). Boot screen repeats status code -100 for brcmfmac. If I remove the stick, boot up, and then plug the stick back in, everything behaves as expected.
Everything booted fine for a week until I tried installing HACS via curl yesterday. After the boot problem came up, I went back and restored a full snapshot prior to the HACS install. The boot issue remained after reloading the snapshot.
Seems like the HACS timing is coincidence. Not sure how to start figuring this out.
