Hey guys,
After setting up my system with the Aeotec usb i decided i wanted to be able to control zigbee devices as well and picked up the HUSBZB-1 (US version) and i cannot figure out how to include or add a node. When i check the log it looks like it starts searching then just gets lazy and says there is nothing to do within a second. I’ve tried having someone else click the button while i tap my mono price muti sensor 2 times and nadda. I also have some zwave dimmers (GE,Honeywell) and they dont see to do anything either. with Aeotec you just had to push the button on the stick and walk around and touch each device to get it paired then in HA they would just show up under integrations>Zwave.
Here is the output when I add a device. anyone who has this working, I would appreciate if you could post the log of a device actually being included/. added.
After going to Z-Wave Network Management > then clicking ADD NODE SECURE (I put a randome network key in my config) and this is the log. same with the plain ADD NODE
2019-11-22 16:16:10.606 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2019-11-22 16:16:10.606 Detail, Notification: ControllerCommand - Canceled
2019-11-22 16:16:10.608 Detail,
2019-11-22 16:16:10.609 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2019-11-22 16:16:10.666 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x14, 0x06, 0x00, 0x00, 0xa0
2019-11-22 16:16:10.666 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-11-22 16:16:10.666 Info, contrlr, ADD_NODE_STATUS_DONE
2019-11-22 16:16:10.666 Detail, Node006, Expected reply was received
2019-11-22 16:16:10.666 Detail, Node006, Message transaction complete
2019-11-22 16:16:10.667 Detail,
2019-11-22 16:16:10.667 Detail, contrlr, Removing current message
2019-11-22 16:16:10.667 Detail, Notification: ControllerCommand - Completed
2019-11-22 16:16:12.698 Detail, Queuing (Controller) Add Device
2019-11-22 16:16:12.698 Info, Add Device
2019-11-22 16:16:12.698 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x15, 0x64
2019-11-22 16:16:12.698 Detail, Notification: ControllerCommand - Starting
2019-11-22 16:16:12.700 Detail,
2019-11-22 16:16:12.700 Info, contrlr, Sending (Command) message (Callback ID=0x15, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x15, 0x64
2019-11-22 16:16:12.704 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x15, 0x01, 0x00, 0x00, 0xa6
2019-11-22 16:16:12.704 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-11-22 16:16:12.704 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2019-11-22 16:16:12.704 Detail, Node001, Expected callbackId was received
2019-11-22 16:16:12.704 Detail, Node001, Expected reply was received
2019-11-22 16:16:12.704 Detail, Node001, Message transaction complete
2019-11-22 16:16:12.704 Detail, contrlr, Removing current message
2019-11-22 16:16:12.704 Detail, Notification: ControllerCommand - Waiting
2019-11-22 16:16:12.705 Info, WriteNextMsg Controller nothing to do
