I bought the Aeotec first, try to config for week, no luck. that’s way i bought the Go Control Quick Stick, and hope it will work, but still no luck to make zwave work, but at least i make Zha work, sadly, I have all my zwave devices on my all my smartthing hub. No zigbee devices
If the Aeotec is still connected, it’s probably /dev/ttyAMA0
If you’re using the HUSBUZB - stop Home Assistant, delete OZW_Log.txt, start Home Assistant and then please share the top 20 lines of the new OZW_Log.txt file.
Oh, and please format it as a code block - see the large blue box at the top for full details, or just select all the lines and push the </> button on the formatting bar.
don’t understand the second part:
“Oh, and please format it as a code block - see the large blue box at the top for full details, or just select all the lines and push the </> button on the formatting bar.”
In with all your configuration files - eg configuration.yaml
When you post walls of logs, or configuration, if you don’t format it correctly it’s hard to read. When you paste them in you then select them all and push that button:
That then ensures that they’re formatted correctly
below is all the files i have in the config folder:
automations.yaml
configuration.yaml
customize.yaml
groups.yaml
harmony_harmony_hub.conf
home_assistant.log
home_assistant_v2.db
insteon_local_lights.conf
insteon_local_switch.conf
phue.conf
scripts.yaml
secrets.yaml
zigbee.db
if you mean home_assistant.log file after i reboot the PI:
2017-11-19 11:43:48 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-11-19 11:43:49 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
After reboot, i can’t reconnect to Assistant GUI, but no error at the log file,
I copy the the string you provide above, IT WORK!!!
the only difference is you have “A SPACE” after "zwave: "
All other component at config file doesn’t require a space after the “:”
Now I can see the Zwave is ready a home assiatant GUI and also OZW_Log.txtfile and pyozw.splite file
Tinkerer, Thanks a lot for you help. ready appreciated.
Now I can Move on and experience with zwave and zigbee devices…
