I bought the Aeotec first, try to config for week, no luck. that’s way i bought the Go Control Quick Stick, and hope it will work, but still no luck to make zwave work, but at least i make Zha work, sadly, I have all my zwave devices on my all my smartthing hub. No zigbee devices
If the Aeotec is still connected, it’s probably /dev/ttyAMA0
If you’re using the HUSBUZB - stop Home Assistant, delete OZW_Log.txt, start Home Assistant and then please share the top 20 lines of the new OZW_Log.txt file.
Oh, and please format it as a code block - see the large blue box at the top for full details, or just select all the lines and push the </> button on the formatting bar.
don’t understand the second part:
“Oh, and please format it as a code block - see the large blue box at the top for full details, or just select all the lines and push the </> button on the formatting bar.”
In with all your configuration files - eg configuration.yaml
When you post walls of logs, or configuration, if you don’t format it correctly it’s hard to read. When you paste them in you then select them all and push that button:
That then ensures that they’re formatted correctly
