HUSBZB-1 Problem
below is all the files i have in the config folder:
automations.yaml
configuration.yaml
customize.yaml
groups.yaml
harmony_harmony_hub.conf
home_assistant.log
home_assistant_v2.db
insteon_local_lights.conf
insteon_local_switch.conf
phue.conf
scripts.yaml
secrets.yaml
zigbee.db
if you mean home_assistant.log file after i reboot the PI:
2017-11-19 11:43:48 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-11-19 11:43:49 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
After reboot, i canā€™t reconnect to Assistant GUI, but no error at the log file,
Hmmm, thereā€™s no sign that itā€™s even attempted to configure Z-Wave.
To check, your Z-Wave configuration looks exactly like:
zwave:
  usb_path: /dev/ttyUSB0
yes, try retype the same sentence so many time, ever copy from example.
Then there should be something in the log (home_assistant.log) about it, saying what the problem is.
I copy the the string you provide above, IT WORK!!!
the only difference is you have ā€œA SPACEā€ after "zwave: "
All other component at config file doesnā€™t require a space after the ā€œ:ā€
Now I can see the Zwave is ready a home assiatant GUI and also OZW_Log.txtfile and pyozw.splite file
Tinkerer, Thanks a lot for you help. ready appreciated.
Now I can Move on and experience with zwave and zigbee devicesā€¦
