Husbzb-1 zha died?
I just arrived home after a vacation to find that my zha network isn’t working any more. I was away the whole time, so nothing has changed about the software, hardware or physical configuration of the network.
I’ve always had a pretty solid performing mesh with mostly plugged-in devices. A few sinope zigbee thermostats, a few sengled smart bulbs and a couple aqara motion sensors (the new version that doesn’t randomly drop from the network).
As mentioned in the topic title, I’m using a husbzb-1 stick. Strangely, the zwave part of the stick still works fine, it’s just the zigbee stuff that’s not working. Everything shows up as unavailable. I’m running hassos on a VM with the stick passed through and it’s worked perfectly for years. I’ve tried rebooting HA, rebooting the VM, plugging and unplugging the husbzb stick and nothing’s working.
I’ve poked through the logs and couldn’t find much that was helpful, but I did find this:
Logger: zigpy.zcl
Source: runner.py:190
First occurred: 7:28:11 PM (4 occurrences)
Last logged: 7:28:11 PM
[0xF63D:1:0xff01] Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 265, in request return await self.device.request( ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request await send_request() File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request await self.send_packet( File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 932, in send_packet raise zigpy.exceptions.DeliveryError( zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102> The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 539, in write_attributes_safe res = await self.write_attributes(attributes, manufacturer=manufacturer) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 81, in wrapper with wrap_zigpy_exceptions(): File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__ self.gen.throw(value) File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 73, in wrap_zigpy_exceptions raise HomeAssistantError(message) from exc homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[0xB0DE:1:0xff01] Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 265, in request return await self.device.request( ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request await send_request() File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request await self.send_packet( File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 932, in send_packet raise zigpy.exceptions.DeliveryError( zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102> The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 539, in write_attributes_safe res = await self.write_attributes(attributes, manufacturer=manufacturer) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 81, in wrapper with wrap_zigpy_exceptions(): File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__ self.gen.throw(value) File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 73, in wrap_zigpy_exceptions raise HomeAssistantError(message) from exc homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[0x8A9F:1:0xff01] Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 265, in request return await self.device.request( ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request await send_request() File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request await self.send_packet( File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 932, in send_packet raise zigpy.exceptions.DeliveryError( zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102> The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 539, in write_attributes_safe res = await self.write_attributes(attributes, manufacturer=manufacturer) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 81, in wrapper with wrap_zigpy_exceptions(): File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__ self.gen.throw(value) File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 73, in wrap_zigpy_exceptions raise HomeAssistantError(message) from exc homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[0x4C66:1:0xff01] Traceback (most recent call last): File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 265, in request return await self.device.request( ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request await send_request() File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request await self.send_packet( File "/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py", line 932, in send_packet raise zigpy.exceptions.DeliveryError( zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102> The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 539, in write_attributes_safe res = await self.write_attributes(attributes, manufacturer=manufacturer) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 81, in wrapper with wrap_zigpy_exceptions(): File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__ self.gen.throw(value) File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 73, in wrap_zigpy_exceptions raise HomeAssistantError(message) from exc homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
