I’ve got ESPHome working on a handful of Adafruit Huzzah ESP8266 boards, and I already have a DHT22 wired up GPIO5 and working wonderfully.
I’m trying to add a NeoPixel Stick. Now, I’ve seen the note in the documentation about using GPIO3, but the huzzah board doesn’t seem to break out GPIO3.
Moreover, I can’t for the life of me, get the neopixel stick to even light up, at all. (I’ve verified it’s in good working order with an esp32)
I’ve tried both the neopixelbus
and the fastled_clockless
. With the neopixelbus I’ve tried almost every variant. Though the product page specifically states it’s either using WS2812
or SK6812
, yet neither work.
Config:
# wsn02
substitutions:
devicename: wilresssensornode02
shortname: wsn02
shortupper: WSN02
esphome:
<<: !include common/common.yaml
esp8266:
board: huzzah
# Enable Home Assistant API
api:
password: !secret api_wsn02
- platform: dht
pin: GPIO5
model: DHT22
temperature:
name: "$shortupper Temperature"
filters:
- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: "°F"
humidity:
name: "$shortupper Humidity"
update_interval: 60s
light:
- platform: neopixelbus
type: GRBW
pin: GPIO2
num_leds: 8
variant: WS2812
effects:
- addressable_scan:
- addressable_color_wipe:
- addressable_rainbow:
- addressable_fireworks:
Logs:
INFO Reading configuration /config/wsn02.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing wsn02 (board: huzzah; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
| |-- Hash @ 1.0
| |-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- ArduinoJson @ 6.18.5
|-- NeoPixelBus @ 2.6.9
| |-- SPI @ 1.0
Compiling .pioenvs/wsn02/src/main.cpp.o
Linking .pioenvs/wsn02/firmware.elf
RAM: [==== ] 40.9% (used 33540 bytes from 81920 bytes)
Flash: [==== ] 44.3% (used 462537 bytes from 1044464 bytes)
Building .pioenvs/wsn02/firmware.bin
esp8266_copy_factory_bin([".pioenvs/wsn02/firmware.bin"], [".pioenvs/wsn02/firmware.elf"])
========================= [SUCCESS] Took 13.80 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of wsn02.home.morphx.net
INFO -> 192.168.2.31
INFO Uploading /config/.esphome/build/wsn02/.pioenvs/wsn02/firmware.bin (466688 bytes)
INFO Compressed to 319240 bytes
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from wsn02.home.morphx.net using esphome API
WARNING Can't connect to ESPHome API for wsn02.home.morphx.net: Timeout while connecting to ('192.168.2.31', 6053)
INFO Trying to reconnect to XXX in the background
INFO Successfully connected to XXX
[20:24:21][I][app:102]: ESPHome version 2022.12.3 compiled on Dec 27 2022, 20:23:15
[20:24:21][C][wifi:504]: WiFi:
[20:24:21][C][wifi:362]: Local MAC: XXXXXXXXXXX
[20:24:21][C][wifi:363]: SSID: [redacted]
[20:24:21][C][wifi:364]: IP Address: XXXXXXX
[20:24:21][C][wifi:365]: BSSID: [redacted]
[20:24:21][C][wifi:367]: Hostname: 'wsn02'
[20:24:21][C][wifi:369]: Signal strength: -57 dB ▂▄▆█
[20:24:21][C][wifi:373]: Channel: 10
[20:24:21][C][wifi:374]: Subnet: 255.255.255.0
[20:24:21][C][wifi:375]: Gateway: XXXXXXX
[20:24:21][C][wifi:376]: DNS1: 8.8.8.8
[20:24:21][C][wifi:377]: DNS2: 1.1.1.1
[20:24:21][C][logger:293]: Logger:
[20:24:21][C][logger:294]: Level: DEBUG
[20:24:21][C][logger:295]: Log Baud Rate: 115200
[20:24:21][C][logger:296]: Hardware UART: UART0
[20:24:21][C][light:104]: Light 'wsn02 Light'
[20:24:21][C][light:106]: Default Transition Length: 1.0s
[20:24:21][C][light:107]: Gamma Correct: 2.80
[20:24:21][C][dht:017]: DHT:
[20:24:21][C][dht:018]: Pin: GPIO5
[20:24:21][C][dht:024]: Model: DHT22 (or equivalent)
[20:24:21][C][dht:027]: Update Interval: 60.0s
[20:24:21][C][dht:029]: Temperature 'WSN02 Temperature'
[20:24:21][C][dht:029]: Device Class: 'temperature'
[20:24:21][C][dht:029]: State Class: 'measurement'
[20:24:21][C][dht:029]: Unit of Measurement: '°F'
[20:24:21][C][dht:029]: Accuracy Decimals: 1
[20:24:21][C][dht:030]: Humidity 'WSN02 Humidity'
[20:24:21][C][dht:030]: Device Class: 'humidity'
[20:24:21][C][dht:030]: State Class: 'measurement'
[20:24:21][C][dht:030]: Unit of Measurement: '%'
[20:24:21][C][dht:030]: Accuracy Decimals: 0
[20:24:21][C][status:034]: Status Binary Sensor 'WSN02 Status'
[20:24:21][C][status:034]: Device Class: 'connectivity'
[20:24:21][C][version.text_sensor:021]: Version Text Sensor 'WSN02 Version'
[20:24:21][C][version.text_sensor:021]: Icon: 'mdi:new-box'
[20:24:21][C][restart.button:017]: Restart Button 'WSN02 restart'
[20:24:21][C][safe_mode.button:022]: Safe Mode Button 'WSN02 safe mode'
[20:24:21][C][safe_mode.button:022]: Icon: 'mdi:restart-alert'
[20:24:21][C][web_server:125]: Web Server:
[20:24:21][C][web_server:126]: Address: XXXXXXXXX:80
[20:24:21][C][mdns:103]: mDNS:
[20:24:21][C][mdns:104]: Hostname: wsn02
[20:24:21][C][ota:093]: Over-The-Air Updates:
[20:24:21][C][ota:094]: Address: XXXXXXXXXXXX:8266
[20:24:21][C][api:138]: API Server:
[20:24:21][C][api:139]: Address: XXXXXXXXXXXX:6053
[20:24:21][C][api:143]: Using noise encryption: NO
[20:24:22][C][wifi_info:009]: WifiInfo IPAddress 'WSN02 IP'
[20:24:42][D][api:102]: Accepted XXXXXXXX
[20:24:42][W][api.connection:083]: Home Assistant 2022.12.8 (XXXXXXX): Connection closed
[20:24:59][D][dht:048]: Got Temperature=22.3°C Humidity=27.8%
[20:24:59][D][sensor:126]: 'WSN02 Temperature': Sending state 72.14000 °F with 1 decimals of accuracy
[20:24:59][D][sensor:126]: 'WSN02 Humidity': Sending state 27.80000 % with 0 decimals of accuracy
What am I missing here, I’ve spent hours with 0 progress.
Cheers.
