Can anyone help with such a scenario:
- Shelly 3EM installed on PV inverter to measure PV production
- HVAC hooked to same circuit as PV, so HVAC directly consumes PV generated power or import from grid if there’s no PV production
- HVAC is duct system so 3 phases such as inverter
I want to create a template that will:
- calculate how much energy HVAC consumed while PV inverter is working + how much energy HVAC consumed while PV is not working (so imported from grid)
So far I’ve got mixed results and my idea is:
- create Shelly 3EM energy exported total sensor
- sensor:
- name: "PV energy exported"
icon: mdi:solar-power-variant
unit_of_measurement: "kWh"
device_class: energy
state_class: total_increasing
state: >
{% set val1 = states('sensor.shelly3em_total_returned_0') %}
{% set val2 = states('sensor.shelly3em_total_returned_1') %}
{% set val3 = states('sensor.shelly3em_total_returned_2') %}
{{ val1 | float(0) + val2 | float(0) + val3 | float(0)
if
is_number(val1) and is_number(val2) and is_number(val3)
else
None
availability: >-
is_number(states('sensor.shelly3em_total_returned_0')) and
is_number(states('sensor.shelly3em_total_returned_1')) and
is_number(states('sensor.shelly3em_total_returned_2'))
- take total energy produced by PV inverter (the problem is it’s updated every 5 min)
Calculate how much energy was used by HVAC by calculating:
- sensor:
- name: "HVAC energy used"
icon: mdi:hvac
state: >
{% set val1 = states('sensor.PV_total_energy') %}
{% set val2 = states('sensor.PV_energy_exported') %}
if
else
None
availability: >-
is_number(states('sensor.PV_total_energy')) and
is_number(states('sensor.PV_energy_exported'))
- calculate grid used energy by HVAC:
- sensor:
- name: "HVAC energy imported from grid"
icon: mdi:hvac
state: >
{% set val1 = states('sensor.shelly3em_total_0') %}
{% set val2 = states('sensor.shelly3em_total_1') %}
{% set val3 = states('sensor.shelly3em_total_2') %}
if
else
None
availability: >-
is_number(states('sensor.shelly3em_total_0')) and
is_number(states('sensor.shelly3em_total_1')) and
is_number(states('sensor.shelly3em_total_2'))
- now it should be an easy one but since inverter production is updated every 5 min I cannot get this to work:
HVAC energy imported from grid + (PV total energy - PV energy exported)
Highly appreciate if any have and idea how to solve that problem.
