Bit of a noob here, need some guidance. I’ve recently installed some duct dampers (coded as a ‘valve’ in HA) in my HVAC ducts that are triggered by a relay. I have temperature sensors in each room, and a Nest thermostat. I’m wanting the dampers to only open or close when the heating cycle in on. I’ve got it working for when the Nest state initially changes to heating, however I’m stuck on how to continue monitoring throughout the heating cycle, and close (or even open) as necessary .
Eg. assuming the room is initially below target (as measured by what the Nest is set to), the duct will open (if it’s not already) when the heating cycle is initially triggered (this works with the code below) - then when the room temperature reaches target temp, the damper gets closed while the heating cycle is still running.
This is what I’ve come up with so far:
alias: North Bedroom
description: ""
triggers:
- trigger: state
entity_id:
- sensor.nest_status
to: heating
conditions: []
actions:
- if:
- condition: numeric_state
entity_id: sensor.atc_e6e9_temperature
below: sensor.nest_thermostat_temp
then:
- action: valve.open_valve
metadata: {}
data: {}
entity_id: valve.lilygo_relay_north_bedroom_damper
else:
- action: valve.close_valve
metadata: {}
data: {}
mode: single
