HVAC controller
I have a heat transfer kit in my house, its completely dumb and cant be automated.
What could i replace the controller with? i dont care if the fan only ever has one speed either.
Kit
https://www.mitre10.co.nz/shop/weiss-1-to-3-room-heat-transfer-system/p/276860
Wiring Diagram
This is exposed and the fan is some sort of selector switch? The selector switch can be removed and replaced with a relay. Question is what is the hp or power draw of the fan? You’ll need a relay that is designed for an inductive load.
Total wattage 55 watts so quite low.
was thinking of using a iFan04-H, thoughts?
That would be what I would use because it’s built to work with inductive fans and that is an important distinction. In fact, I’m going to end up with a spare of those very soon as I’m replacing my Sonoff fan controller with an Inovelli Zigbee - so if you want one cheap you could buy mine, it’s already flashed with ESPHome.
I did this
you have to use a 3 relay one
Nice to see another kiwi on here, is there a certain model number i should look for?
search for “Keyes Relay modules”
