HW-622 Board Setup - Single relay, single input (opto isolated) ESP8266 ESP-12F ($3.80AUD)
Hi folks,
I am new to ESPHome and could not find anything on these boards. They seem pretty cheap and have a relay and opto-isolated input which is what I wanted. Was tricky for a new guy to work i out so thought I’d post here while it was fresh.
(Schematics and discussion about the board Blynking an IoT Yunshan ESP8266 250V 10A AC/DC WIFI Network Relay Module | µC eXperiment)
Hope this is of use to someone. I also have a 4 relay board that I’ll do a similar post on.
I bought mint (HW-622) here ~$4 AUD : [DC 5V-26V ESP8266 ESP-12F Wireless Wifi Relay Module 220V 10A Relay Module ESP12F 802.11b/g/n 2.4GHz 12V 24V]((DC 5V 26V ESP8266 ESP 12F Wireless Wifi Relay Module 220V 10A Relay Module ESP12F 802.11b/g/n 2.4GHz 12V 24V|Relays| - AliExpress)
To flash from HomeESP use this connection:
and it should appear in ESPHome.
Once it was in ESP Home, I then edited the config for it in ESPHome and reflashed it using this config:
esphome:
esp8266:
  board: esp12e
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "83x2bxxxxxxxx87xxxxxx8"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.0.142
    gateway: 192.168.0.254
    subnet: 255.255.255.0
  ap:
    ssid: "Relaysingle Fallback Hotspot"
    password: "4tVxxxxxxxxtSf"
captive_portal:
# Use the blue LED in the device as a status LED, which will blink if there are warnings (slow) or errors (fast)
status_led:
  pin:
    number: GPIO2
    inverted: True
# One  relay outputs, exposed as switches in Home Assistant
switch:
  - platform: gpio
    pin: GPIO4
# One sensor input
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO5
      mode:
        input: true
        pullup: true
    device_class: door
type or paste code here
Then remove the “boot” jumper and serial cable
Add the device IP to ESPHome (I use fixed IP’s)
Next, for me, I connected the external ground to the ESP ground pin and so could see the sensor input working in Home assistant.
Thanks a great deal for this Andrew, I had spent so much time looking for information on this board and it wasn’t until I searched HW-622 that I found your post.
Much appreciated,
Thierry
This is great and super helpful … But one detail below
The grounding of the reset pin is risky. On some of the ones I have the RST is strapped directly to VCC with a wide trace under the ESP module. So grounding reset will create a short and may destroy F1, a 1A diode. I would skip the reset grounding to be safe.
I would like to point out that the “Reset Pin” can be used as 3v3 VCC, so you can power the thing entirely from the UART module.
The downside to this is that the UART doesn’t have enough power to also trigger the relay and can only power the relay’s red LED.
Thank you @Andrew123. this is a brilliant post and helped me worked through the lack of information with this board.
I have my board up and running and I’ll definitely be using more of them around my home.
Keep up the great work, Take care
Duncan
For anyone else that might stumble upon this thread, @Andrew123 did a solid job in describing the initial setup (including jumping the GND/Reset pins, I wasn’t able to get it working without that)
If you’re using a CP2102 USB to Serial converter like I have, I had to flip my TX/RX wires (as shown below) to get the board to flash correctly.
Thanks Andrew123 for your post. I have flashed it correctly, I will also try to connect an OLED display and a temp sensor to turn it into a thermostat.
During flashing I was getting an error like
Failed to connect to ESP8266: Invalid head of packet (0x00): Possible serial noise or corruption.
But I discovered it was due to the fact I only connected TX/RX and not the ground pin to the programmer.
Great post @Andrew123 by far the best ive seen regarding hw -622. What i would like to know is tbe maximum output from the 5v out. Im hoping its enough to power 6m strig of 5v sk6812. I would like to know prior to finding out myself !
Update: sorry i dont know how i missed the post from @crust about the F1 1amp fuse.
Thank you.
unlikely. You need to look up the specs for the particular strip you have. The one I looked up said 18W/meter. I assume that is full on and it has 60/meter. That is over 3A/meter. You need a big power supply for that.
And therefore you cannot short it to ground. Fatal.
My board ESP12F single relay board
Programar HW-622 (ESP8266 + Relé + Optoacoplador) para Home Assistant
Basado en experiencia real y troubleshooting con DeepSeek
Excelente el aporte de Andrew123. Lástima no haberlo encontrado antes, pero dado que con la ayuda de DeepSeek logré hacer funcionar el HW-622, comparto mi experiencia para ayudar a otros.
:laptop: Mi setup de programación
Cargué el código con:
“esphome run HW622.yaml” # o el nombre que le pongas desde terminal Linux. Importante: Windows dio innumerables problemas con velocidad y detección de puertos. Linux funciona siempre de primera.
:clipboard: RESUMEN: Programar HW-622
  1. Configuración BASE probada y funcionando
esphome:
friendly_name: HW-622 Relay
esp8266:
board: esp12e
framework:
version: 3.1.2 # Versión estable probada
restore_from_flash: false
board_flash_mode: dout
wifi:
ssid: “Tu_SSID”
password: “Tu_Password”
fast_connect: false # ¡IMPORTANTE! false para que escanee como Arduino
power_save_mode: none
Usa DHCP para primera prueba (después puedes poner IP fija)
  1. Pinout CORRECTO del HW-622
Componente Pin GPIO Observación
Relé GPIO4 Activo HIGH
Entrada Opto GPIO5 Usa pull-up interno
LED Azul (D4) GPIO2 ¡INVERTIDO! (LOW = encendido)
  1. LED Status (el famoso GPIO2)
FORMA CORRECTA de controlar el LED azul
output:
  • platform: gpio
    pin:
    number: GPIO2
    inverted: true # ¡CRÍTICO! Sin esto no enciende
light:
  • platform: binary
    name: “LED Estado HW-622”
    output: led_azul
  1. Relé y Entrada Optoacoplador
switch:
  • platform: gpio
    pin: GPIO4
    restore_mode: ALWAYS_OFF # El relé arranca apagado
binary_sensor:
  • platform: gpio
    name: “Entrada Opto HW-622”
    pin: GPIO5
    device_class: motion # o window, door según uso
    filters:
    • delayed_on: 50ms # Antirrebotes
    • delayed_off: 50ms
      on_press:
      then:
      • switch.toggle: relay
  1. Web Server para pruebas rápidas
web_server:
port: 80 (no es necesario)
  1. LOGS útiles para debug
logger:
level: DEBUG
baud_rate: 115200
logs:
wifi: DEBUG # Ver conexión WiFi
esp8266: INFO
component: INFO
:wrench: Comandos útiles
Ver puertos disponibles
ls /dev/ttyUSB* # o /dev/ttyACM*
Compilar y subir
esphome run config.yaml --device /dev/ttyUSB0
Solo compilar (sin subir)
esphome compile config.yaml
Ver logs sin subir
esphome logs config.yaml --device /dev/ttyUSB0
Limpiar caché cuando hay errores de paquetes
rm -rf ~/.platformio
:bullseye: Configuración FINAL para HW-622
La configuración completa que funcionó:
esp8266:
board: esp12e
framework:
version: 3.1.2 # ¡CLAVE!
wifi:
fast_connect: false # ¡CLAVE!
output:
  • platform: gpio
    pin:
    number: GPIO2
    inverted: true # ¡CLAVE!
light:
  • platform: binary
    output: led_azul
    restore_mode: ALWAYS_ON # El LED se enciende al iniciar
:light_bulb: Bonus: Automatización útil
binary_sensor:
  • platform: gpio
    name: “Sensor Opto HW-622”
    pin:
    number: GPIO5
    mode: INPUT_PULLUP
    filters:
    • delayed_on: 50ms
      on_press:
      then:
      • light.toggle: led
      • homeassistant.event:
        event: esphome.hw622_triggered
        message: “Opto activado!”
¡Gracias a Andrew123 por el informe y a DeepSeek por la ayuda en el debugging!
