HX711 output as percentage?
I have a HX711 set up as a filament spool weight sensor. I’m wondering is there anyway you have that output to home assistant as a percentage? Right now its just showing weight in kg. Thank you for any help.
Sure. Use a filter of some kind, or a template sensor. The template sensor has the advantage of letting you have both the weight and percentage still available.
  - platform: hx711
    dout_pin: D0
    clk_pin: D1
    gain: 128
    update_interval: 60s
    on_value:
      - sensor.template.publish:
          state: !lambda 'return x/4.2 * 100;' # formula for percentage of max weight
                 # 4.2 is the full weight, be clever and take into account spool weight
                 # something like (x-.5)/3.7 * 100
    name: "Percentage Remaining"
    unit_of_measurement: "%"
Thank you! I will give this a try!!
Ok I got the empty and full weights. Im using rubber made food storage as dry boxes so there is always some weight.
Empty = .87kg
Full = 2.06kg
How can I right that so it shows the percentage of just the spool? This template stuff always confuses me. Thanks again for the help!
edit: would that be this…
“return - .87 / 2.06 * 100”
It would be something like this:
‘return (x - 0.87)/ (2.06 - 0.87) * 100;’
