Hydreon RG-15 rain sensor
Any new readings? Are those things accurate? I bought one to test it out.
@BliXem
Yes. I have not ā€œcalibratedā€ but for my purposes it looks good.
The device produces a number of entities; if you have programmed the RG-15 on the most sensitive settings, it will show some activity with low sunlight/ mist / dirt etc. On mine this doesn’t necessarily trigger a ā€œRain Eventā€ (which is another entity) but if you need to trigger a Home Assistant automation from a proper rain event occurring, then I would construct a HA template which triggers on say 0.1mm (i.e. ignoring condensation and sunlight). This works really well for me
Hi Julian,
Thanks for your reply! Alright, there are some activity events that won’t trigger the ā€˜it’s raining’ event like low sunlight/mist/dirt on the highest setting. Can you share your (template) code please? :-). Not only for me but also for others with the same issue.
I’m glad that it’s accurate then.
@BliXem
This is my template sensor … I guess you could/should really make it a binary sensor … but I have used text as a return… and it works
- sensor:
    - name: "Rain State"
      unique_id: rainstate
      device_class: enum
      state: >
        {% if states('sensor.tubpit_rain_intensity') | float(0) > 0.1 %}
          Raining
        {%- else -%}
          Dry
        {%- endif %}
Did someone connect the RG-15 via ESPhome on uart via a ESP32 device? It boots up with 3 green flashes, but then my ESP hangs, looses wifi and restart again like 3 times… Connected via J2, port 1 for ground, 4 for rxd, 5 for TXD and 8 for 3v3…
Nevermind, where bad cables :slight_smile:
Well its not working for me. It I remove the dome it’s working, if I reattach the dome my esp32 hangs, boot loops, don’t understand :frowning:
I’m using it with 5V power. The documentation says it needs a stable 3.3V supply on J2.
TX and RX are still 3.3V level signals.
It also says that it can induce false indications or affect accuracy. I don’t think it’s related with the boot loops… Without the dome all is working better then when the dome is attached.
On tasmota it’s working perfectly. So there is a bug within ESPHome. Will report it I guess.
I do notice that on a slightly cloudy day where clouds and sun alternate frequently in a short time, rain is detected. Do others also experience this issue?
