Hydro Quebec sensors give an error fetching the balance
When trying to setup HydroQuebec sensor for the first time I received an “Error while setting up platform hydroquebec”. After reading the log I fount the following error:
File "/usr/lib/python3.6/site-packages/pyhydroquebec/client.py", line 185, in _get_balances
    balances.append(float(balance[:-2].replace(",", ".")))
ValueError: could not convert string to float: '-1\xa0627.47'
Balance: -1 627.47 (Yeah this is very unusual)
I suspect it is relate to my account been in credit (negative balance) or the space separation for the thousand. Before I submit a bug I would like to confirm with the community if isn’t something else since I’m new to HA . Any comment? Thanks.
Home Assistant release (hass --version):
0.60.1
Python release (python3 --version):
HASSIO - 3.6.3
Component/platform:
hydroquebec
Description of problem:
When trying to setup HydroQuebec sensor for the first time I received an “Error while setting up platform hydroquebec”. After reading the log I strongly suspect it is because presently my account is negative.
Expected:
Show my HydroQuebec account information
Problem-relevant configuration.yaml entries and steps to reproduce:
# Weather prediction
  - platform: hydroquebec
    username: xxxxxxxxxx
    password: xxxxxxxxxx
    contract: '#########'
    monitored_variables:
     - period_length
     - period_total_days
  1. Add the config above to configuration.yaml
  2. Restart Pi3
  3. Look at the Log
Traceback (if applicable):
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 171, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/hydroquebec.py", line 108, in setup_platform
    ", ".join(hydroquebec_data.get_contract_list()))
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/hydroquebec.py", line 176, in get_contract_list
    self._fetch_data()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/hydroquebec.py", line 183, in _fetch_data
    self.client.fetch_data()
  File "/usr/lib/python3.6/site-packages/pyhydroquebec/client.py", line 296, in fetch_data
    balances = self._get_balances()
