Hyperion Integration Broken?
Hello, I have multiple installs of Hyperion NG that I have been using with Home Assistant. Up until recently I had all 3 installs connected, but I’ve recently changed machines and when I went to add the second install to HA it tells me “Already Configured” Does anyone know how to fix this? None of the installs are reused from other machines + they’re both new installs.
2024-01-28 17:54:41.990 INFO (MainThread) [hyperion.client] Connected to Hyperion server: xx.xx.xx.50:xx
2024-01-28 17:54:41.991 INFO (MainThread) [hyperion.client] Connected to Hyperion server: xx.xx.xx.69:xx
The logs show it as connecting to both servers as well.
I also have the 3rd install, which when I try to add it, it just says Failed to connect
I tried to do it using another instance of home assistant on a Pi and am running into the exact same thing on both of those devices
