Hi all,
I’m trying to ‘integrate’ my Hyperion setup into Home Assistant to be able to control it.
Unfortunately, no entities or devices are created after adding the following to my configuration.yaml :
#Hyperion Server Setup:
#light:
- platform: hyperion
host: 192.168.2.20
port: 19333
default_color: [0,0,255]
Mind, the #
before light
is because different lights are specified above it.
Earlier i’ve seen some errors in the home-assistant.log, but right now nothing about hyperion is written over there…
I’ve tried several ports also, for example: 19400, 19444, 19333, 8090 as i’m not 100% sure which port is meant to be filled in (they go by names like: flat, proto, etc)
Anyone with any clue on how to get this to work or where to start searching?
Thanks in advance.
