I need some help with my Hyperion setup in Home Assistant. I am running Hyperion.NG on a Raspberry Pi and I previously had it working perfectly where Home Assistant could control and toggle all the settings. Long story short, I tried to update my Hyperion.NG to the latest build and encountered issues. I ended up reformatting and reinstalling Hyperion.NG from scratch with the latest 2.0.0-alpha 11 build. Now Home Assistant will connect to the Hyperion but the on/off toggle for it is broken. As an example if the LEDs on the Hyperion are on and I use Home Assistant to turn them off they will turn off⌠However the toggle for the entity immediately flips back to âOnâ and it acts like the entity is unavailable so I can no longer use the toggle to actually switch the lights back on. The vice versa is also true if the lights are off and I try to toggle them on. The only error I see in the logs is the following:
I decided to wipe my Hyperion and downgrade to the alpha-9 version⌠works perfectly again in Home Assistant. Upgraded it back to alpha-11 and itâs broken again. Looks to be a bug somewhere that is causing compatibility issues with the Home Assistant integration
Not for me it hasnt, fresh install of Hyperion today on a raspi using the Hyperion Image, HA just spits out âFailed to connectâ,
which is odd, because my 2 other instances running 2.0.12 on windows are working fine
