It would be great to have a native field to utilize for a hysteresis parameters when using the numeric trigger for automations. I see most users are utilizing the threshold sensor as a work around.
You could do two separate numeric_state triggers, one for above and one for below.
I’m not sure that would accomplish what I’m after. I’m wanting a deadband setpoint. Say I’m monitoring humidity greater than 70% and I want a hysteresis of 5. I should not receive another high humidity notification unless it has dropped below 65% then climbed to trigger my 70% threshold again.
You can achieve your goal with a input Boolean used as memory and 2 automations.
First Automation:
Trigger: Humidity> 70%
Condition: Memory = FALSE
Action: Notification + Set Memory to TRUE
SecondA Automation:
Trigger: Umidity <65%
Action: Set Memory to FALSE
And you can create a Boolean as a threshold sensor and have one automation. The nature of my request is to integrate this all into the numeric trigger so it’s factory.
Much later… having the same problem.
It sounds very simple for the logic, but quite complicated workaround.
I have an idea how this could be implemented in a generic way.
It would be nice to have a section similar to trigger, but as an “arming” for the actual trigger. Or think about it like a 2 stage trigger.
Whether it should be called “arming”, or “pre-trigger”, I don’t know (or care )
The logic would be: the pre-trigger (stage 1) is just enabling the normal trigger (stage 2).
This way one can implement time hysteresis (e.g. a device must be off a certain duration before allowing turning on again), or numerical hysteresis like you wanted here…
