Hi all,
Posted on UVO thread, I guess I can also share this here.
Thanks @anon63427907 (and @fuatakgun and @wcomartin and all involved) ! This is great to be able to fetch data from uvo/bluelink
I’m using this integration and managed to push bluelink data to ABRP ![]()
(inspiration came from here)
First create a rest_command in configuration.yaml:
update_abrp:
method: POST
headers:
content_type: "charset=utf-8; application/x-www-form-urlencoded"
url: >
{% set tlm = {
"utc": as_timestamp(strptime(states('sensor.kona_last_updated_at'), "%Y-%m-%dT%H:%M:%S%z")),
"soc": states('sensor.kona_ev_battery_level'),
"soh": states('sensor.kona_ev_state_of_health_battery'),
"est_battery_range": float(states('sensor.kona_ev_range')),
"is_charging": states('sensor.kona_is_charging'),
"lat": state_attr('device_tracker.kona_location', 'latitude'),
"lon": state_attr('device_tracker.kona_location', 'longitude'),
"odometer": states('sensor.kona_odometer')
https://api.iternio.com/1/tlm/send?api_key=your_api_key_from_iternio&token=your_token_from_abrp_app&tlm={{tlm|to_json|urlencode}}
# https://documenter.getpostman.com/view/7396339/SWTK5a8w#api-endpoints
then this automation will push the telemetry each time an update is received by the integration:
alias: Télémétrie KONA vers ABRP
description: ''
triggers:
- trigger: state
entity_id:
- sensor.kona_last_updated_at
conditions: []
actions:
- action: rest_command.update_abrp
data: {}
response_variable: status
Now I have to figure out what are the best value for scan without beeing locked until the rest of the day (got “to many request” error in bluelink app while playing with ABRP)
