By which sensor do I get the charging speed of an Ioniq 5?
Whoopsies!
Hi.
Integration support region Russia (Bluelink Huyndai)?
Can be region RUSSIA added?
I want to report that the integration does not work with Hyundai Kona Electric in EU region.
It does say No Devices or Entities when initializing.
@TGR Here it works like a charm. They had some downtime in May, but it is working again since June 2nd. I have a Kona, the Account was created in August 22. I heard older accounts could cause problems.
The account was created 2 months ago. Country of usage - Bulgaria.
Interesting…
Can I provide/check some logs for troubleshooting?
Located in Luxembourg, owning Kia Niro Phev, all works fine.
Please follow github issue template, generate logs and upload there.
Any Idea, why i can´t find the following entities anymore: ( I´m driving a Kona EV 2020)
ev_daily_odometer
ev_battery_kw
Some entities are getting lost on the data end, check if they exist on debug/data entity, we are storing the response of the api for validation purposes there
New problem in my setup.
Now I am getting
““Error communicating with API: Unconverted data remains AM””
Could please someone point me to the right direction
Hyundai Kona EU
First time I have seen, please enable debug logs following README file, create an issue and share your logs. Do not forget to sanitize them before sharing
I did send you a e-mail.
The template for your wife’s car looks awesome! Would you mind posting the code for it? I’d love to try and adapt it for our Palisade.
Sharing what I’ve done for my Ioniq 6
Here’s the card:
type: vertical-stack
cards:
- type: picture-elements
image: /local/images/ioniq6.png
elements:
- type: state-label
entity: sensor.2023_ioniq_6_ev_range
style:
color: grey
top: 24%
left: 11%
- type: state-icon
entity: sensor.2023_ioniq_6_car_battery_level
icon: mdi:battery-50
style:
color: grey
top: 9%
left: 11%
- type: state-label
entity: sensor.2023_ioniq_6_ev_battery_level
style:
top: 9%
left: 16%
card_mod:
style: |
:host {
color:
{% set level = states('sensor.2023_ioniq_6_ev_battery_level')|float(0) %}
{% if level > 80 %}
#ffc107
{% elif level > 20 %}
#4caf50
{% else %}
#808080
{% endif %}
- type: state-icon
title: 12v
state_color: true
style:
top: 5%
left: 28%
transform: scale(1.1, 1.1)
- type: state-label
style:
top: 11%
left: 40%
card_mod:
style: |
:host {
color:
{% set level = states('sensor.2023_ioniq_6_car_battery_level')|float(0) %}
{% if level > 65 %}
#4caf50
{% elif level > 0 %}
#ff5722
{% else %}
#808080
{% endif %}
- type: state-icon
entity: binary_sensor.2023_ioniq_6_air_conditioner
icon: mdi:air-conditioner
title: null
state_color: true
style:
left: 45%
top: 1%
- type: state-label
entity: sensor.2023_ioniq_6_odometer
style:
color: grey
left: 85%
top: 10%
- type: state-icon
entity: binary_sensor.2023_ioniq_6_ev_battery_plug
state_color: true
style:
top: 40%
left: 97%
- type: state-icon
entity: binary_sensor.2023_ioniq_6_tire_pressure_all
style:
top: 70%
left: 78%
- type: state-label
entity: device_tracker.2023_ioniq_6_location
style:
color: grey
top: 70%
left: 26%
- type: service-button
title: Start AC
service: kia_uvo.start_climate
service_data:
device_id: [my_device_id]
target: {}
style:
color: grey
top: 90%
left: 86%
- type: state-label
entity: sensor.2023_ioniq_6_last_updated_at
show_last_changed: true
style:
top: 86%
left: 36%
color: grey
title: Update
service: kia_uvo.update
service_data:
target: {}
style:
color: grey
top: 92%
left: 22%
- type: custom:stack-in-card
mode: vertical
keep:
background: false
border_radius: false
box_shadow: false
margin: false
outer_padding: false
cards:
- type: glance
entities:
- entity: binary_sensor.2023_ioniq_6_ev_battery_plug
- entity: sensor.2023_ioniq_6_estimated_charge_duration
name: Time to charge
- entity: binary_sensor.2023_ioniq_6_fuel_low_level
- entity: sensor.2023_ioniq_6_ev_range
show_state: true
show_name: true
state_color: true
- type: custom:bar-card
icon: mdi:battery-charging
entities:
- entity: sensor.2023_ioniq_6_ev_battery_level
columns: '0'
entity_row: false
direction: right
positions:
icon: outside
indicator: 'off'
minmax: 'off'
value: inside
severity:
- color: '#FFC107'
to: '100'
- color: '#4CAF50'
to: '80'
- color: '#FF5722'
to: '19'
entities:
max: 240
min: 0
severity:
- color: Red
to: 48
- color: Orange
to: 191
- color: Green
to: 240
- type: glance
entities:
- entity: binary_sensor.2023_ioniq_6_tire_pressure_all
- entity: sensor.2023_ioniq_6_car_battery_level
- entity: sensor.2023_ioniq_6_odometer
show_state: true
show_name: true
state_color: true
- type: custom:button-card
styles:
grid:
- grid-template-areas: '"i n l"'
- grid-template-rows: 100%
- grid-template-columns: 25% 45% 30%
label:
- justify-self: start
name:
- justify-self: end
- margin-right: 10%
name: 'Last Updated:'
aspect_ratio: 7/1
- type: custom:mushroom-entity-card
tap_action:
action: call-service
target: {}
hold_action:
service: kia_uvo.force_update
target: {}
- type: gauge
severity:
green: 20
yellow: 80
red: 0
needle: true
unit: '%'
I put the 800x600 png image for my car in the /config/www/images folder. To find the device_id value for my vehicle, I’m sure there is a more efficient way, but I created a custom:mushroom-entity-card with the tap action to call service kia_uvo:Update. The card’s visual editor let me select a vehicle, then I switched to the code editor and copied the device_id. Alternatively, I later realized that the device_id is in the URL when you find the device from the Setting menu.
I thought it might be cool to have two images one with the front battery flap vents open and this one with them closed and have it change based on if the car is home or away but I’m not sure that can be done. I also don’t think the icons inside the picture elements card can be conditionally based on the charge level I get from Bluelink.
I really wish I could track my mi/kWh in Home Assistant over time.
Hi all,
I just installed the Bluelink integration, but upon adding my bluelink credentials, i get this error:
It retries every min or so but fails each time.
I have tested my credentials online.
I am in Canada driving a Hyundai.
Where can i grab the logs?
Please create a GitHub issue with full debug logs, what you have posted is a glimpse of it without anything useful information
