cow138
(Andrew)
December 28, 2018, 1:40pm
1
Hi.
Just to check with the folks here. I am a total newbie. Realised that I bought a model B instead of B+.
Can i still use the same setup procedure as I am not able to assess my hassio local through the browser.
Even after connecting to the ethernet and waiting for the required 20 mins
silvrr
December 28, 2018, 6:49pm
2
Don’t use Hassio.local. Find the actual ip of the pi and use that.
A pi 3 b+ should be ok with any of the current install methods. Which one doc you use?
cow138
(Andrew)
December 29, 2018, 3:24am
3
Thanks for helping out. I just hope its not the Model B thats causing the problems
I used
Raspberry Pi 3 Model B and B+ 32bit
I am not too sure whether its possible to use or not…and btw how do I check the IP address of the Pi?
I have it attached to one of the ethernet lan ports of my router
nickrout
(Nick Rout)
December 29, 2018, 3:56am
4
Your router will have a list of clients. Or use fing on an Android device.
cow138
(Andrew)
December 29, 2018, 6:47am
5
Thanks. Let me check it out.
No such luck till now… But is the Raspberry model B suitable for home assistant?
nickrout
(Nick Rout)
December 29, 2018, 7:17am
6
Yes. The + is better specced but the plain 3 will be fine.
cow138
(Andrew)
December 29, 2018, 11:15am
7
Thanks. At least it won’t be a white elephant for now. What should I do now?
Attempt to reflash the sdcard and start all over?
