I’m running Frigate in HA on a Proxmox VM in an Intel NUC. It’s catching people and I get snapshots but I can’t get clips. I get, “The media could not be loaded, either because the server or network failed or because the format is not supported.”
Is something missing in my config or someplace else? I’m very new to yaml and have reviewed the Frigate docs several times, tried various syntax but can’t figure it out.
This error is very generic and can mean a lot of different things. You need to check the frigate logs. If you see an error which says it can’t find the recording then record is likely not enabled.
Otherwise, it is either that your camera is h.265 and your browser does not support h.265 playback. In any case, you can go to chrome://media-internals/ in chrome which will show a log of why playback failed
I have an Amcrest camera that can record either h.264 or h.265. Mine was set to h.264h. I changed it to h.264 but hat shouldn’t make any difference right?
My Frigate logs say, “No recordings found for the requested time range”, so that means record is not enabled. I thought my frigate.yml has recording enabled. Is something off in the config that I show in my original question?
It’s been a real slog trying to get this going but I appreciate the help I’m getting here.
That doesn’t matter. Frigate is only available to be run in a container, so it is either running in docker in a VM or it is running in an LXC container (in your case).
Go to the main cameras screen. Live view means nothing as that is always enabled
With all that being said, the only reason you wouldn’t have clips at this point is if there are other errors in your logs. Other than that I really have no idea
Clips are just date/time. When viewing a clip it will be created from the recorded video.
No recorded video. No clip.
Missing recording has many cause
-slow storage
-bad storage
-ffmpeg stop
-out of memory and recording stop for current period and restarted
-and on and on
For this reason lioking at logs will help.
But how to do this? I look at logs using portainer. It allows log viewing. There is also log stored but i dont know how to access im addon.
Anyway, find the log and it will either tell you theres a problem or not. You also not using coral i believe. This may lead to out of memory and no recording. But, no log no know why
