And here is what happens when I run Home Assistant:
(homeassistant) homeassistant@Home-Control-Mac-Mini homeassistant % hass --open-ui
Unable to find configuration. Creating default one in /Users/homeassistant/.homeassistant
2020-11-15 19:22:47 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package pillow==7.2.0: ERROR: Command errored out with exit status 1:
command: /Users/homeassistant/homeassistant/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py'"'"'; __file__='"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-record-6dctw50q/install-record.txt --single-version-externally-managed --compile --install-headers /Users/homeassistant/homeassistant/include/site/python3.9/pillow
cwd: /private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/
Complete output (172 lines):
running install
running build
running build_py
creating build
creating build/lib.macosx-10.9-x86_64-3.9
creating build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MpoImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageMode.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PngImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/XbmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PcxImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/SunImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/SpiderImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TarIO.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FitsStubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MpegImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BdfFontFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GribStubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageStat.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PixarImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GimpPaletteFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageColor.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ContainerIO.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MspImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MicImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_version.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImtImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GifImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PalmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageQt.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageMath.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PaletteFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FontFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PdfParser.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ExifTags.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageCms.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FpxImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageChops.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BufrStubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PSDraw.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PcdImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageFilter.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageDraw2.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImagePath.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/DcxImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/__init__.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/JpegPresets.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/features.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageDraw.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GimpGradientFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageWin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/IcoImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_tkinter_finder.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/EpsImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TgaImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageMorph.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/WalImageFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PcfFontFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BlpImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageTk.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GbrImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageOps.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PdfImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageShow.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageEnhance.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/WmfImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageGrab.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/WebPImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FliImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TiffTags.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/CurImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_util.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GdImageFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TiffImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/IptcImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImagePalette.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BmpImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageTransform.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/IcnsImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/McIdasImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/XpmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/DdsImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageSequence.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PyAccess.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_binary.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/Image.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/__main__.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/XVThumbImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/SgiImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PsdImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/JpegImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageFont.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PpmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FtexImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
writing top-level names to src/Pillow.egg-info/top_level.txt
reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.ci'
writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
running build_ext
The headers or library files could not be found for zlib,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
https://pillow.readthedocs.io/en/latest/installation.html
File "/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py", line 864, in <module>
setup(
File "/Users/homeassistant/homeassistant/lib/python3.9/site-packages/setuptools/__init__.py", line 165, in setup
return distutils.core.setup(**attrs)
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/core.py", line 148, in setup
dist.run_commands()
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/Users/homeassistant/homeassistant/lib/python3.9/site-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/command/install.py", line 546, in run
self.run_command('build')
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/command/build_ext.py", line 340, in run
self.build_extensions()
File "/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py", line 694, in build_extensions
raise RequiredDependencyException(f)
__main__.RequiredDependencyException: zlib
File "<string>", line 1, in <module>
File "/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py", line 918, in <module>
raise RequiredDependencyException(msg)
ERROR: Command errored out with exit status 1: /Users/homeassistant/homeassistant/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py'"'"'; __file__='"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-t0muno3a/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-record-6dctw50q/install-record.txt --single-version-externally-managed --compile --install-headers /Users/homeassistant/homeassistant/include/site/python3.9/pillow Check the logs for full command output.
WARNING: You are using pip version 20.2.3; however, version 20.2.4 is available.
You should consider upgrading via the '/Users/homeassistant/homeassistant/bin/python3 -m pip install --upgrade pip' command.
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: ['pillow==7.2.0'].
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2020-11-15 19:22:47 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2020-11-15 19:22:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2020-11-15 19:22:54 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2020-11-15 19:22:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2020-11-15 19:22:54 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2020-11-15 19:22:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: person
2020-11-15 19:22:54 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2020-11-15 19:22:58 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook, map, mobile_app, person
2020-11-15 19:22:58 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-11-15 19:22:59 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
2020-11-15 19:23:03 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package pillow==7.2.0: ERROR: Command errored out with exit status 1:
command: /Users/homeassistant/homeassistant/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py'"'"'; __file__='"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-record-ui6n4f1c/install-record.txt --single-version-externally-managed --compile --install-headers /Users/homeassistant/homeassistant/include/site/python3.9/pillow
cwd: /private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/
running install
running build
running build_py
creating build
running egg_info
running build_ext
File "/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py", line 864, in <module>
setup(
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
cmd_obj.run()
File "/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py", line 694, in build_extensions
File "/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py", line 918, in <module>
ERROR: Command errored out with exit status 1: /Users/homeassistant/homeassistant/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py'"'"'; __file__='"'"'/private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-install-o7avkq0n/pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /private/var/folders/ys/j24x01wj6m17stn8w0kqd2540000gp/T/pip-record-ui6n4f1c/install-record.txt --single-version-externally-managed --compile --install-headers /Users/homeassistant/homeassistant/include/site/python3.9/pillow Check the logs for full command output.
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: ['pillow==7.2.0'].
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of safe_mode. Setup failed for dependencies: frontend
2020-11-15 19:23:03 ERROR (MainThread) [homeassistant.setup] Setup failed for safe_mode: Could not set up all dependencies.
2020-11-15 19:23:03 WARNING (SyncWorker_5) [homeassistant.bootstrap] Cannot launch the UI because frontend not loaded
