i can not start any new addons in Home Assistant.
Every addon in install new I can not start.
I click in the addon on start but nothing happend. Normally when I start an addon, the two buttons restart and stop are displayed. But if I click on start now, the blue circle turns briefly and then start is there again.
When I try to start an addon for the first time, the logs say:
INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.1.3
But the addon still says start.
If I click the start button again and look in the supervisor logs, it says e.g. e.g. something like this:
23-02-26 14:57:20 WARNING (MainThread) [supervisor.addons.addon] core_mosquitto is already running!
Now I stopped the addon with an automation:
service: hassio.addon_stop
addon: core_mosquitto
If I then click on start again in the addon, this is what the log says:
23-02-26 14:59:41 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquitto
This happens to me with every addon right now.
I have already imported an older backup of Home Assistant several times. Unfortunately without success.
In another thread, someone assumes that I may have multiple Docker containers with the mqtt broker, which is where the problem comes from. He suggested that I should install the “Portainer” addon so that I can take a closer look at the Docker containers. But unfortunately I can’t start this addon either
Does anyone have any other ideas what I can try?
